Print at Sep 28, 2026, 1:52:50 AM
Posted by Puybaret at Dec 28, 2010, 3:46:50 PM
Re: import obj with texture
mekkelek,
You can edit the MTL file if you want to, but you should know that Sweet Home 3D doesn't support all the options available in the MTL format.
For example, map_Kd lines that specify information about texture, supports only a file name for the image of the texture and no scale or shift options.
If the exported MTL file shows such options, you should modify the UV coordinates of your model in Maya in such a way the texture image don't need any scale.
