Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Door swing in plan » » » » Post: Re: Door swing in plan |
Print at Sep 26, 2026, 10:20:51 AM |
| Posted by Puybaret at Dec 31, 2010, 2:31:48 PM |
Re: Door swing in plan Mita, Hans, There's no way to specify a door swing in OBJ format. The OBJ format isn't that clever! If you want to achieve that with your own model, you should create a custom SH3F file containing your door model (use Furniture Library Editor if you want to), and add the following properties in the PluginFurnitureCatalog.properties file contained in the SH3F zipped file (where n is the number of the model): doorOrWindow#n=trueBy example, the default door defined in Sweet Home 3D catalog is defined this way: name#19=DoorI guess it's not so easy to handle but it's the way all doors and windows are defined in Sweet Home 3D. I'll try to add some options about doors in a future version of the Furniture Library Editor. Finally, if you just want to show the swing of doors and windows defined in the 3D models page, please consider downloading the SH3F files that contain all of them with correct definition. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 10:20:51 AM |
