Print at Sep 26, 2026, 11:40:17 PM
Posted by hansmex at Jan 5, 2011, 4:09:37 PM
Re: Loft conversion plan
Ian,
Easy? That depends on the definition:
- download any *.skp model
- open it in Sketchup
- export it as a 3D model (*.dae)
(- import it in SH3D)
Now, there's a small problem: you can't insert triangular windows in walls. SH3D assumes windows to be rectangular, and leaves gaps around a triangular window. So, the trick is to make the triangular window square, Depending on the exact form of the window, you can combine it with a few triangles until you have a rectangle. In general this can be done in SH3D. If you need an upside-down triangle, export a normal one, and re-import it, and make sure that you change the orientatien during import.
One you have enclosed your triangular window to make it rectangular:
- export the rectangular window as OBJ file
- import it and check the Door/Window check-box while importing.
You may want to give the triangles the correct colour/texture before importing it, because otherwise everything gets the same colour/texture.
Easy? Well... mmmhhmm... But consider this: how long does it take to teach yourself Blender??
