Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't load IA 32bit .dll on a AMD-64bit platform » » » » Post: Re: Can't load IA 32bit .dll on a AMD-64bit platform |
Print at Oct 4, 2026, 10:40:46 PM |
| Posted by Puybaret at Jan 12, 2011, 4:40:22 PM |
Re: Can't load IA 32bit .dll on a AMD-64bit platform I should probably deliver a 64 bits version for Windows too. You probably use a 64 bits JRE, but could you try if 64 bits IE accepts to run applets with a 32 bits JRE? As I think the Online applet is run in a separate process, I don't know if it would work. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 10:40:46 PM |
