Print at Oct 15, 2026, 4:18:16 PM
Posted by kamelie at Jan 20, 2011, 7:51:37 AM
confused   Installation on Win XP without admin rights
Hello,
I am happily using on my home machine (Linux Ubuntu) and I try to get is installed on my work laptop (WinXp) without the admin rights.
Here is what I have tried
- Use the EXE install package: Installation stopped because of lack of admin rights
- Use of Java webstart installation.
-- Installation when well and I have a menu option pointing to "C:\WINDOWS\system32\javaws.exe -offline "C:\Documents and Settings\Fincra\Application Data\Sun\Java\Deployment\cache\javaws\http\Dwww.sweethome3d.com\P80\AMSweetHome3D.jnlp"
-- I get the splash screen then nothing.
-- I could not find any log
- use of the jar file
-- launch by using the command "java -jar SweetHome3D-3.0.jar"
-- I got the splash screen and the following error message
20 janv. 2011 09:46:35 java.util.prefs.WindowsPreferences <init>
ATTENTION: Could not open/create prefs root node Software\JavaSoft\Prefs at root
0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: LUT h
as improper length!
at javax.imageio.ImageTypeSpecifier$Indexed.<init>(Unknown Source)
at javax.imageio.ImageTypeSpecifier.createIndexed(Unknown Source)
at com.sun.imageio.plugins.png.PNGImageReader.getImageTypes(Unknown Sour
ce)
at com.sun.imageio.plugins.png.PNGImageReader.readImage(Unknown Source)
at com.sun.imageio.plugins.png.PNGImageReader.read(Unknown Source)
at javax.imageio.ImageIO.read(Unknown Source)
at com.eteks.sweethome3d.swing.PlanComponent.createCustomCursor(Unknown
Source)
Source)
at com.eteks.sweethome3d.swing.PlanComponent.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createPlanView(Unknown S
ource)
at com.eteks.sweethome3d.viewcontroller.PlanController.getView(Unknown S
ource)
at com.eteks.sweethome3d.viewcontroller.PlanController$SelectionState.mo
veMouse(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController$SelectionState.en
ter(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController.setState(Unknown
Source)
at com.eteks.sweethome3d.viewcontroller.PlanController.<init>(Unknown So
urce)
at com.eteks.sweethome3d.viewcontroller.HomeController.getPlanController
(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown S
ource)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown S
ource)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionCha
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.run(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$3.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Java version used is
java version "1.5.0_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_07-b03)
Java HotSpot(TM) Client VM (build 1.5.0_07-b03, mixed mode)
Any idea how to proceed?
Thanks
