Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: not enough sunlight? » » » » Post: not enough sunlight? |
Print at Oct 2, 2026, 12:18:44 PM |
| Posted by macfrog at Jan 23, 2011, 10:32:40 PM |
not enough sunlight? emmanuel, hans, now after i nearly finished the outer hull of my home, including roof, i came to the conclusion (i mentioned light issues before...) the incoming sunlight is much to dark in most cases. maybe its not "correctly" reflected from walls or whatsoever, but i think a room with lots of glass should look flooded with light at noon. is the radiosity support somebody brought up a while ago still on the table and would that solve my "problem"? btw i had to finish the entire house because you said its not possible/wanted to look from top into a room and block sunrays coming in from ceiling without enabling ceilings (and therefore ceiling lights) - as i remember correctly. so now i can actually see proper light conditions. greets macfrog |
Current timezone is GMT Oct 2, 2026, 12:18:44 PM |
