Print at Oct 16, 2026, 2:05:17 PM
Posted by hansmex at Jan 25, 2011, 1:13:16 PM
Round walls aren't round?
Emmanuel,
I always wanted to make a spiral staircase like this one:
So, I devised a way to make it in SH3D using round walls. This is how I did it:
- draw a round wall with an angle of 180 degrees
- correct XY coordinates to exact round numbers
- make it sloping from 300 to 0.1 cms
- then use CopyAsNewFurniture, Paste, Export to OBJ format
- Import furniture twice, rotating the second model so that it's upside-down.
- stack the two objects, and voila.
It's only then that I discovered that (1) round walls aren't perfectly round or (2) that I must have done something wrong. The image below shows a clear band on the left where the top and lower half don't line up.
Do you have a solution?
