Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: cutting empty window holes... » » » » Post: Re: cutting empty window holes... |
Print at Oct 2, 2026, 3:04:21 AM |
| Posted by hansmex at Jan 31, 2011, 8:40:49 PM |
Re: cutting empty window holes... macfrog, Of course there is a solution. 1 - Download this arch from the 3D models section. 2 - Import it twice: first time normal, second time rotate it until upside-down. Both times make sure to check the box Door/Window. 3 - Insert both arches in your design, give them the same coordinates, then give the upper one the correct elevation, and group them. 4 - Resize the grouped arches to the correct size and elevation, then insert them in your wall. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 2, 2026, 3:04:21 AM |
