Print at Oct 5, 2026, 3:17:18 AM
Posted by chipmaster at Feb 4, 2011, 11:21:33 AM
Re: Run SH3D via Remote Desktop
I found 2 ways to start SH3D on windows without 3D card (like Amazon EC2 instance):
1) you can setup Oracle vitual machine and run Ubuntu instance. Don't forget turn on 3D acceleration checkbox in settings. Then run SweetHome 3D using Java WebStart. Disadvantage: Oracle VirtualBox uses only one core
2) setup SweetHome 3D using windows installer. Then download SwiftShader 2.01, unpack d3d8.dll and d3d9.dll from SwiftShader archive near the SweetHome3D.exe (by default path can be "C:\Program Files\Sweet Home 3D" or "C:\Program Files (x86)\Sweet Home 3D", depends on the 32 or 64 bit architecture). Then right click on SweetHome3D.exe -> Properties -> Compatibility -> select Windows XP SP2 (or SP3). Then run SweetHome3D.exe. Voila! It works!
I prefer second method because SH3D uses all cores in this case :)
