Print at Sep 29, 2026, 2:05:34 PM
Posted by hansmex at Feb 21, 2011, 10:42:59 PM
Re: projection of room walls on a 2D plan
Deverne,
I can't follow what you're trying to explain, and it's not because of my English...
If you share your SH3D file, maybe that would explain some things. You can also share a Java file, maybe someone else understands that (but not me).
1 - The command Plan --> Export to SVG format produces an SVG file with a high quality 2D plan, but I guess that's not what you want? Do you need a cross-section? Can you give an example of what you need? Some image from Google Images maybe?
2 - I tried drawing a few rooms in all kinds of orders: clockwise, counterclockwise, random direction walls. When I inspect the inserted rooms with the AdvancedEdit plug-in, all room points are given in clockwise order, so that doesn't confirm your suspicion, although the plug-in may sort room points in that order.
