Print at Sep 28, 2026, 8:02:24 AM
Posted by Puybaret at Feb 22, 2011, 9:01:31 AM
Re: projection of room walls on a 2D plan
Deverne,
I'm not sure to fully understand what kind of projection you're trying to build, and for which purpose.
A drawing is sometimes much more helpful than any word.
If you're trying to create a parallel projection, using Java 3D parallel projection should help you to get a result much faster (but you won't get an SVG output).
You can upload your code anywhere and add a link to it here.
