Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Problem running sweet home from source in eclipse !!! » » » » Post: Re: Problem running sweet home from source in eclipse !!! |
Print at Oct 3, 2026, 2:23:32 PM |
| Posted by Puybaret at Mar 2, 2011, 9:14:26 AM |
Re: Problem running sweet home from source in eclipse !!! Before trying to modify the source code, I would try to reproduce the steps explained in the Plug-in developer's guide. Did you try that? And about running Sweet Home 3D from its sources in Eclipse, did you try change the VM arguments as explained in the README.TXT file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 2:23:32 PM |
