Print at Oct 2, 2026, 4:26:58 AM
Posts: 13   Pages: 2   [ 1 2 | Next Page ]
Posted by 2manyprojects at Feb 23, 2020, 6:09:51 PM
Launch multiple instances of SweetHome3D?
I searched around and could not find an answer.
Is there a way to launch multiple instances of SweetHome3D?
I am using the linux version and launching SweetHome3D-Java3D-1_5_2.
Attempts so far to launch multiple instances, even from different source locations just shows the one currently running instance.
Thanks,
M-
Posted by Puybaret at Feb 25, 2020, 6:07:31 AM
Re: Launch multiple instances of SweetHome3D?
It’s not possible without dirty tricks, but I could add an option for that in a future version. Why do you need that?
Posted by rrraf at Mar 1, 2021, 12:26:38 AM
I would also love that in order to be able to launch (night long) "multiple photo rendering" in multiple designs/files. Unless there's another way to achieve this?
Regards
Posted by Puybaret at Mar 3, 2021, 6:55:18 PM
I added the com.eteks.sweethome3d.singleInstance system property in Sweet Home 3D 6.5 to make each launch of the application run in a separated process when set to false.
To use this property, add the line
-Dcom.eteks.sweethome3d.singleInstance=false
to a file named SweetHome3D.l4j.ini and stored in Sweet Home 3D installation folder.
Posted by Mike53 at Mar 3, 2021, 10:07:11 PM
Would that enable us to use 2 instances of sunflow too?
Posted by Puybaret at Mar 3, 2021, 10:11:06 PM
Yes, but both instances will try to use all the cores of the CPU, so I’m not sure it will be efficient.
Posted by The_Highlander at Jul 4, 2025, 1:12:42 AM
I too would like to be able to run two instances of your excellent program but I cannot find any file named: "SweetHome3D.l4j.ini" in the Sweet Home 3D installation folder (or anywhere else on my computer).
I am running version 7.5 of the program on a Windows 10 PC.
Does the facility only exist for Linux users or can you tell me how to do it in Windows 10 please?
Thank you, &
Kind Regards.
There can be only one! 😊
Posted by Puybaret at Jul 4, 2025, 10:16:06 AM
Just create the file SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe
Posted by The_Highlander at Jul 4, 2025, 8:21:41 PM
Hoping that I had understood you correctly, I created a new text file (as shown below), renamed it as:"SweetHome3D.l4j.ini", opened it (with r/click > Edit ) and inserted the single line:-
"-Dcom.eteks.sweethome3d.singleInstance=false"
then saved it and moved it into the folder containing: "SweetHome3D.exe"
Having done that, I can, indeed, now open two instances of the program simultaneously!
Thank you so much for your help (and for your excellent program!). applause
Best Regards. biggrin
Posted by Keet at Jul 5, 2025, 8:48:12 AM
Be aware that with separate instances you won't see a newly imported furniture or texture library in one instance in the other instance until you restart it. With a single instance setup you would see an imported library immediately in all open projects. In your case I don't think that will be a problem but remember it when you have two instances running for normal editing and you import furniture or textures.
Also understand that photo rendering will not be faster by doing it in two instances at the same time instead of one after the other. The only advantage is that you can start them both and let them run through the night.
