Print at Oct 4, 2026, 1:59:08 PM
Posted by justthewayur at Apr 1, 2020, 4:01:48 PM
.png image on wall or object with transparancy...
Can I make either a vertical wall or object, apply a .png image of a tree that has transparancy around the tree, then see that in a 3d view and have the transparent areas of the .png image be invisible, the same as a .png behaves as a 2d image ?
Thank you.
Justina
Posted by Puybaret at Apr 2, 2020, 6:43:46 PM
Re: .png image on wall or object with transparancy...
You may do that on the side of a thin box found in Miscellaneous category, but not on walls.
Posted by justthewayur at Apr 3, 2020, 5:13:37 PM
Thank you.
May I ask for a tip please on how to plan the correct size of the image and dpi if I wish a real life size of 5 feet tall by 4 feet wide, and maintain the aspect ratio of the image on the box without stretching.
Cheers.
Posted by Puybaret at Apr 3, 2020, 5:36:51 PM
It's explained in this tip.
Posted by justthewayur at Apr 8, 2020, 4:34:47 PM
Thank you.
[Solved]
