Print at Sep 30, 2026, 5:06:27 AM
Posted by jmadero at Apr 11, 2020, 4:26:24 PM
SweetHome3d Not Seeing My Data Partition in Linux
Hi All,
I've been using Linux for over 15 years and I can say this is a first. Sweet Home 3D is not seeing my main data partition. I separate /, /home, and /data, for various reasons.
lsblk output
├─sdb5 8:21 0 29.3G 0 part /
├─sdb6 8:22 0 24.4G 0 part /home
├─sdb7 8:23 0 222.7G 0 part /data
SweetHome3d Open Dialog
Additionally, my shortcuts to the /data/XXXX folders within my Home Folder are all missing in SH3D. Finally, permissions are pretty standard, 770, for the data partition.
This is super bizarre. Any suggestions welcome.
Posted by dorin at Apr 13, 2020, 12:23:33 PM
Re: SweetHome3d Not Seeing My Data Partition in Linux
Me too. I have also separate partitions for different purpose.
Normal. All other programs act the same (Libre Office, Inkscape, kate etc.)
At start are mounted in system ONLY "/" and "/home".
All other partitions have only shortcuts in file browser.
First I need to click on it then insert the root password to mount it in the system.
For many personal reasons I don't like to use sudo.
After that I found it in file chooser (from every program) under:
Root/media/ my_user_name / partition_name
That's applicable for every new reboot or boot.
At least that's the way I use my linux systems.
I use debian with KDE.
Hope is useful.
P.S. An general advice: DON'T use the repository version.
Use the installer version from this site.
Posted by UbuntuBirdy at Apr 13, 2020, 2:22:11 PM
I'm using Linux (Ubuntu) only since 12 years, so you guys are the pros. But I solved this problem with "systemd":
systemd man page.
I put it in the fstab so a mount point looks like this:
/home/"user"/music nfs nfsvers=4,noauto,x-systemd.automount,x-systemd.idle-timeout=900,users,rw 0 0
This is for a NAS via nfs, but it works also for partitions.
The mount point is not mounted (this saves you booting time) until you access it, but all the programs can do that.
Perhaps this could be a solution for you...
Posted by jmadero at Apr 15, 2020, 8:08:15 PM
It is mounted. LibreOffice and every other application sees the mount and I have permissions to access. It's literally just Sweet Home 3d. It's an EXT4 partition.
Posted by UbuntuBirdy at Apr 15, 2020, 8:40:23 PM
My partitions, NAS, server, RaspberryPi, all mounted with systemd the way I wrote it in my last post, are all accessible with Sweet Home 3D without any restrictions. And these are Ext4, FAT or NTFS partitions.
So, for me systemd is the one and only thing to mount with (also because of many other options and features).
Posted by jmadero at Apr 15, 2020, 8:44:44 PM
Thought that some additional details could help:
FSTAB
UUID=06461143-2fd0-4dee-b4cd-826690435ec5 /data ext4 defaults 0 2
View from LibreOffice Dialog:
View from Sweet Home Dialog:
As can be seen, "/data" is just entirely missing from Sweet Home Dialog....it's extremely bizarre. I can see /data in LibreOffice and access it without a hitch.
Posted by jmadero at Apr 15, 2020, 8:46:20 PM
And of course the image option didn't work:
LibreOffice: https://drive.google.com/open?id=1rL-54REVMHg1ITCucFE8vwcN46prj37E
Sweet Home: https://drive.google.com/open?id=1dn0TPggTGaZjsBwqmpto7mvZM27WxpkE
Posted by UbuntuBirdy at Apr 15, 2020, 10:09:06 PM
and what's in the "mnt" folder?
Posted by jmadero at Apr 16, 2020, 1:29:01 AM
/mnt/Synology
/mnt/Windows
(two other shares in my FSTAB)
Posted by UbuntuBirdy at Apr 16, 2020, 4:35:00 AM
Ok, other idea: normally you need root rights to access any folder or file in the root directory (they are read-only). So, could this be the reason for your issue?
Posted by jmadero at Apr 18, 2020, 3:56:23 AM
nope:
drwxrwx--- 15 joel shared 4096 Jan 19 18:09 data
Owner is "joel" (my user), group is "shared" (my shared group with my wife and myself), perms are pretty straight forward 770. The fact that it works in literally every other application I use (pdf viewer, web browsers, libreoffice, text editors, handbrake, vlc, literally tens of programs) leads me to think that this is a bug in Sweet Home.
Posted by UbuntuBirdy at Apr 18, 2020, 10:12:11 AM
If this is a bug, it does not affect my system:
I created a "Data" folder like you have it in the root directory. Then I mounted a partition into this mount point.
And as you can see, I can access it via SweetHome3D.
Posted by jmadero at Apr 18, 2020, 2:45:32 PM
Thanks for testing that!
Okay - next question I have. Your distro and version of Sweet Home installed?
I'm running a Ubuntu derivative (Bodhi Linux, built on Ubuntu 18.04), used Snap to install Sweet Home.
Posted by jmadero at Apr 18, 2020, 2:52:15 PM
Bingo - it's the snap version. I just used the more generalized Linux version and it worked. If you have time to test the Snap version...then I can report the issue.
Posted by UbuntuBirdy at Apr 18, 2020, 5:55:42 PM
I do not need to test the snap version. On my Ubuntu 18.04 the snap version does NOT run!
I'm always running the latest sh3d downloaded from this site.
Posted by jmadero at Apr 18, 2020, 9:24:17 PM
I'll report my bug :) Thanks for the assistance. The fact that you did that last test made me think "what could possibly be different" and then that led to a workable solution.
Posted by UbuntuBirdy at Apr 18, 2020, 10:16:35 PM
Together we can solve every problem! This is why I'm working with Linux since many years!
Posted by dorin at Apr 19, 2020, 11:07:48 AM
@UbuntuBirdy
Me too!
@jmadero
No problem! Don't forget the repository version, appimage, snap and what ever other UNOFFICIAL versions.
Don't forget also, for those versions, are not responsible Emmanuel.
