Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I raise the base height of a wall? |
| Print at Oct 4, 2026, 8:50:19 AM | |
| Posted by P10GE at Apr 11, 2020, 5:16:19 PM |
How do I raise the base height of a wall? Hi All, Been using the free version for a while and moved to the paid version thinking the limitation was in the free version but I cannot work out how to make the base height of the wall different? I want to box in the top of a staircase so a cupboard can be put below it. thanks in advance. |
| Posted by Puybaret at Apr 12, 2020, 8:19:13 PM |
Re: How do I raise the base height of a wall? You can’t, create an intermediate level or see this tip for possible solutions. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by P10GE at Apr 17, 2020, 6:48:49 PM |
Re: How do I raise the base height of a wall? Thanks for the reply and instruction. |
| Posted by Alex210 at Apr 23, 2020, 9:43:35 PM |
Re: How do I raise the base height of a wall? Did you find the solution? If yes then ok or if not then check this tip hope it might help. |
Current timezone is GMT Oct 4, 2026, 8:50:19 AM |
