Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: [Q] Merge several plans |
| Print at Oct 13, 2026, 9:31:23 PM | |
| Posted by docsnyder at Apr 18, 2020, 4:10:25 PM |
[Q] Merge several plans Hi sweeties! Although my question should not be hard to be answered, I didn't find any solution via FAQ or google. Question: I made plans of several rooms separately. Now, I want to make a new plan "my flat" merging all the single plans into "one" single plan. How this can be done? As a first guess, I marked all objects of a room and copied them into the clipboard. But, creating a new plan (the "big one") opens a new window (instead opening a new plan as a new TAB inside the already running application). Within the new plan, the "paste" option is inactive, so I can't paste the content of the clipboard. Any idea? What I am doing wrong? Any help is appreciated. |
| Posted by hansmex at Apr 18, 2020, 5:18:20 PM |
Re: [Q] Merge several plans You can have more than one instance of SH3D running at the same time. Copy in #1, than paste in #2. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by dorin at Apr 18, 2020, 8:41:39 PM |
Re: [Q] Merge several plans On the new plan click on plan window or on furniture list then You could paste what You have in clipboard. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Shroom at Aug 13, 2020, 2:28:47 PM |
Re: [Q] Merge several plans Hi, it says this doesn't work on Linux maybe, and unfortunately it doesn't. So is there another option? |
| Posted by Puybaret at Aug 14, 2020, 6:29:24 AM |
Re: [Q] Merge several plans What error or unexpected behavior do you get? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by otadmin at Sep 1, 2020, 11:27:40 AM |
Re: [Q] Merge several plans Same problem here. Have 2 instances open. Copy a wall in one and try to past into the other. But nothing happens. LinuxMint20 cinnamon, SH3D 6.2 |
| Posted by Puybaret at Sep 1, 2020, 1:18:31 PM |
Re: [Q] Merge several plans Open the second instance from the first one, with File > Open or File > Open recent, and be sure to give the focus to the plan in the document where you want to paste items. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by otadmin at Sep 2, 2020, 7:57:30 AM |
Re: [Q] Merge several plans Can confirm that the last advice is working! Thanks for a useful program with many features. |
| Posted by harbinger at Sep 3, 2020, 3:54:30 AM |
Re: [Q] Merge several plans This nifty trick should go into the help manual... |
| Posted by otadmin at Sep 4, 2020, 6:51:10 AM |
Re: [Q] Merge several plans There is a nifty trick as I discovered using it. The opened 2nd instance needs more then one level. If it has 2 levels, I can only copy to level 0. Something I can live with once I know it. I use it as I designed a 4 storey villa. To create the interior with furniture and wallpaper I copy each storey into an extra file. This way my file size stays smaller too. |
Current timezone is GMT Oct 13, 2026, 9:31:23 PM |
