Print at Sep 24, 2026, 10:08:58 AM
Posted by SebStaeubert at Apr 21, 2020, 6:55:33 AM
Startup problem with initializing 3D (Debian 10 Linux, Intel i5-4570 onboard graphic)
Exception starting via script:
./SweetHome3D
Exception in thread "main" java.lang.ExceptionInInitializerError
at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348
at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
Caused by: com.jogamp.opengl.GLException: Profiles [GL4bc, GL3bc, GL2, GLES1] not available on device null
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1039)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050)
at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803)
at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
... 7 more
Java version:
java -version
openjdk version "1.8.0_232"
OpenJDK Runtime Environment (build 1.8.0_232-8u232-b09-1~deb9u1-b09)
OpenJDK 64-Bit Server VM (build 25.232-b09, mixed mode)
GLX-Info
glxinfo
name of display: :1
display: :1 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_no_error,
GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel Open Source Technology Center (0x8086)
Device: Mesa DRI Intel(R) Haswell Desktop (0x412)
Version: 18.3.6
Accelerated: yes
Video memory: 1536MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Haswell Desktop
OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.3.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth,
GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect,
GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,
GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_derivative_control, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_indirect_parameters,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding,
GL_ARB_shader_clock, GL_ARB_shader_draw_parameters,
GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store,
GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_tessellation_shader, GL_ARB_texture_barrier,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float,
GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ATI_blend_equation_separate,
GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_blend_equation_separate,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_framebuffer_fetch_non_coherent,
GL_EXT_shader_integer_mix, GL_EXT_shader_samples_identical,
GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
GL_EXT_vertex_array_bgra, GL_EXT_vertex_attrib_64bit,
GL_IBM_multimode_draw_arrays, GL_INTEL_performance_query,
GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior,
GL_KHR_robustness, GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image,
GL_S3_s3tc
OpenGL version string: 3.0 Mesa 18.3.6
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
GL_ARB_ES3_1_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_color_buffer_float,
GL_ARB_depth_texture, GL_ARB_derivative_control, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_filter_anisotropic,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color,
GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix,
GL_EXT_shader_samples_identical, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_INTEL_performance_query, GL_KHR_blend_equation_advanced,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 18.3.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_APPLE_texture_max_level, GL_EXT_base_instance,
GL_EXT_blend_func_extended, GL_EXT_blend_minmax, GL_EXT_buffer_storage,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
GL_EXT_frag_depth, GL_EXT_geometry_point_size, GL_EXT_geometry_shader,
GL_EXT_gpu_shader5, GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_separate_shader_objects,
GL_EXT_shader_io_blocks, GL_EXT_shader_samples_identical,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_norm16, GL_EXT_texture_rg,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_unpack_subimage, GL_INTEL_performance_query,
GL_KHR_robustness, GL_MESA_framebuffer_flip_y,
GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
GL_NV_fbo_color_attachments, GL_NV_image_formats, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external,
GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
GL_OES_depth_texture_cube_map, GL_OES_draw_buffers_indexed,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_geometry_point_size,
GL_OES_geometry_shader, GL_OES_get_program_binary, GL_OES_gpu_shader5,
GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_primitive_bounding_box, GL_OES_required_internalformat,
GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array
70 GLX Visuals
The problem occurs since i have to change my graphics card from Radeon HD 3850 to intel onboard graphics. So in principle i have a working setup except the 3D graphic setup issue with SH3D. Other 3D Appl. work, e.g. glxgears.
THX, Sebastian
Posted by dorin at Apr 21, 2020, 6:25:54 PM
Re: Startup problem with initializing 3D (Debian 10 Linux, Intel i5-4570 onboard graphic)
1. Go into Your home and rename .eteks folder to .eteks1;
2. Execute SweetHome3D by double-click and accept "Execute";
3. Help->About to see what You run (if You run something);
4. If it run delete .eteks and rename .eteks1 to .eteks;
5. Run again;
6. If NOT OK You have to retry and dig deeper or wait another help.
Posted by SebStaeubert at Apr 21, 2020, 8:09:13 PM
@dorin: Thx for your reply.
Unfortunately renaming the ~/.eteks folder has no effect.
Running SH3d in 2D mode works, but is only as half as nice.
Finaly i found the bug! It was in my SH3D start script. To run SH3D with my Radeon graphics card i had to set this:
export MESA_GL_VERSION_OVERRIDE=3.1
After uncommenting this, SH3D works with the intel onboard graphics card! cool
Posted by dorin at Apr 21, 2020, 8:21:33 PM
That's why I love linux. I could make everything ( well, almost).
In my installation I keep the original to have a point of references and then I make a lot of modifications which usually fail.
But sometimes don't and I'm very happy!
I'm glad You've find the solution!
Posted by SebStaeubert at Apr 21, 2020, 11:41:46 PM
Good idea, thx :-)
Posted by Trucoto at Jan 25, 2021, 6:01:00 PM
I am having the same problem. I installed the regular version that comes with Ubuntu 20.10 and everything works except recording video. I tried downloading the version from here and I have:
$ ./SweetHome3D
Picked up JAVA_TOOL_OPTIONS: -Dfile.encoding=UTF-8
My graphic card is reported as "Mesa IntelĀ® HD Graphics 620 (KBL GT2)"; I tried adding "export MESA_GL_VERSION_OVERRIDE=3.1" to SweetHome3D script but to no avail. I also tried renaming my .eteks directory. Any ideas?
Posted by apribek at Feb 6, 2021, 11:55:00 AM
I have Mesa Intel(R) UHD Graphics 620 (WHL GT2). The
"export MESA_GL_VERSION_OVERRIDE=3.0" in the start script did the trick for me.
