Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: can not start SweetHome3D - error not support |
| Print at Sep 28, 2026, 11:31:46 AM | |
| Posted by tobias_mueller at Feb 28, 2009, 11:55:00 AM |
can not start SweetHome3D - error not support hello first sorry for my bad english! ( hope you can understand it ) when i start SweetHome3D this error: ./SweetHome3D Java 3D ERROR : GLX extension is not supported GLX version 1.3 or higher is required javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D picture like this: http://www.imgimg.de/bild_errord0814205png.png.html my system: opensuse 10.3 what is wrong? what for information do you need? [Note: this thread was started on sourceforge.net forums] |
| Posted by pencilart at Feb 28, 2009, 6:08:00 PM |
Re: can not start SweetHome3D - error not sup I hope this helps: Go here for info on OpenGL: http://en.wikipedia.org/wiki/Opengl scroll down to where it says, "Associated utility libraries" and get all the packages mentioned that you can find. I have packages like, freeglut, sdl, and xorg-x11-server-glx and things like that on my system. They may have changed the names of the packages by now, I don't know (I'm running SuSE 10.0 - it's considered to be old). |
| Posted by Olaf_Noehring at May 16, 2009, 11:57:00 AM |
Re: can not start SweetHome3D - error not support Hi you should use the latest driver for your graphics card. In case you are using a TFT monitor, check out this (http://www.rarst.net/software/cleartype-install4j-java-bug/) or this (http://www.team-noehring.de/php/cmsmadesimple...E&cntnt01returnid=219) which might point you into a good direction. Olaf |
Current timezone is GMT Sep 28, 2026, 11:31:46 AM |
