Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Log Siding Texture & Color - Pluspuu |
| Print at Sep 29, 2026, 10:14:12 AM | |
| Posted by manishlulla at Apr 28, 2020, 12:24:09 PM |
Log Siding Texture & Color - Pluspuu Hi All Power Users, Hope you are well. I am looking for a log siding / log home look as per the below links can you please help me to identify if a pre-existing color texture can achieve this look? https://www.pluspuu.fi/en/mallisto/nauvo-roofdeck/ Thank you so very much in advance! Best regards, |
| Posted by SeppoV12 at Apr 30, 2020, 9:59:23 PM |
Re: Log Siding Texture & Color - Pluspuu There is two sites where I have found that kind of textures: SketchUp Textures and Texturify. Many other exists but look for seamless textures. This texture might be pretty close you are looking for When needed, I have made slight color/tone/size changes with programs like Paint.NET. Good luck for search! |
| Posted by hansmex at May 1, 2020, 12:00:30 PM |
Re: Log Siding Texture & Color - Pluspuu Looks like black or charred wood to me. So maybe one of these ? ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by manishlulla at May 3, 2020, 1:00:40 PM |
Re: Log Siding Texture & Color - Pluspuu Thank you very much! |
| Posted by manishlulla at May 23, 2020, 2:39:18 PM |
Re: Log Siding Texture & Color - Pluspuu Hi Hansmex and SeppoV12, I was able to download the images and apply as texture. However the image splits into squares. Is there a specific size or format I should be using to apply the image. Thank you |
| Posted by hansmex at May 23, 2020, 3:25:28 PM |
Re: Log Siding Texture & Color - Pluspuu That's caused by a texture that isn't "seamless". Search again adding "seamless|tileable" to your search terms. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by manishlulla at May 23, 2020, 3:54:11 PM |
Re: Log Siding Texture & Color - Pluspuu Thank you! |
| Posted by manishlulla at May 23, 2020, 3:58:37 PM |
Re: Log Siding Texture & Color - Pluspuu Thank you again for the help! When I import the texture and apply it the siding lines appear at uneven heights, not all siding lines are equidistant. How do I fix that? Thank you very much! |
Current timezone is GMT Sep 29, 2026, 10:14:12 AM |
