Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: seperate walls/ detache, (not split) |
| Print at Oct 4, 2026, 10:09:25 PM | |
| Posted by hebeentuin at May 3, 2020, 7:32:50 PM |
seperate walls/ detache, (not split) Hello, I'm still figuring out if it's good to draw the walls of the house all together, that way the are attached, or to make all walls seperately. How can I detache a wall? I did find how to splitt a wall, but this splits it at a different place, I want to split it in the corners. is this possible? thankyou |
| Posted by Puybaret at May 3, 2020, 8:14:59 PM |
Re: seperate walls/ detache, (not split) You can detach a wall from the others with a cut-paste operation. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 10:09:25 PM |
