Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create objects from walls? |
| Print at Oct 2, 2026, 4:33:27 AM | |
| Posted by s_koch at May 28, 2020, 7:44:53 AM |
Create objects from walls? Hi and good morning to all, I am on a good way and created some simple objects from walls. For example a half-round counterdesk. But my question: does someone know an "easy" method to solve this: when I use different colors for left and right side of the wall, I end up in the exported and reimported object with different "materials". What is perfect, as I want to use different textures for the front and on the rear side of my counterdesk. But on the top and on the ends, there are those half-and-half colors (or textures), what I can easily solve with an extra very thin wall at the ends. But for the top, I need to create an object now - some kind of top-plate ("tabletop") what has this specific form of a half-round plate. And so I search for an "easy" method to create such "top-plate" from the wall, or maybe from the object in a second step... ups, just getting a phonecall, I try to show some screenshots thanks !!!! |
| Posted by hansmex at May 28, 2020, 8:46:18 AM |
Re: Create objects from walls? Make your walls just a few cm high and insert a room that acts as the counter top. Export and import as furniture. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by s_koch at May 28, 2020, 11:10:57 AM |
Re: Create objects from walls? Wow, so, also rooms can be used for a creation of objects. This "problem" is solved, let´s wait for the next ;-)) Many thanks again! I really appreciate your help. |
Current timezone is GMT Oct 2, 2026, 4:33:27 AM |
