Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Subfloor or platform |
| Print at Oct 2, 2026, 12:20:07 PM | |
| Posted by BKLX at Jun 5, 2020, 12:15:44 PM |
Subfloor or platform Hello, I'm a novice on this forum and on this sftware. And to complicate... I'm French! So I need help to create a ''subflore'' or a ''platform'' I'm not sure of the good word. To complicate, this false floor has not the same perimeter than the real one. If you can help me I will appreciate Have a good day Bruno |
| Posted by Skanderbeg13 at Jun 30, 2020, 12:51:06 AM |
Re: Subfloor or platform I believe that you can use the Box on the miscellaneous to make a platform then just change the texture of the box to your liking. now the house floor and the subfloor wont be at the same level, you can just make the wall a bit higher and just add the same box just wider on the floor and just elevate your furniture and doors and windows a bit and you should get what i belive is a subfloor This is what i did: This is to show that the floor inside is the same level as the outside one: you said that it doesnt have the same perimeter as the real floor: P.S i did the subfloor on the outside so i can show it you can do it inside as well,more professionally, (Your house probably looks a lot better) I hope i could help with this one ![]() |
Current timezone is GMT Oct 2, 2026, 12:20:07 PM |
