Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: import 3d model |
| Print at Sep 25, 2026, 7:45:22 AM | |
| Posted by bruce111 at Jun 6, 2020, 11:09:55 AM |
import 3d model hallo ! I import model .obj ( a plant) but is gray also there is a folder texture with 5 file I'm not able to use it… Someone can help me? thanks |
| Posted by Puybaret at Jun 6, 2020, 7:15:34 PM |
Re: import 3d model If there's no MTL file with your OBJ file, there won't be any color. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ceciliabr at Jun 7, 2020, 12:58:22 PM |
Re: import 3d model Your images might be in the wrong format. SH3D can only load .jpg .png and .gif If your files are in any other format (which is often the case with 3D objects you buy or download for free), you need to convert them before they can be imported to SH3D. There are some free online converters that will do this for you. |
| Posted by GhyslainB at Jan 25, 2021, 2:21:09 AM |
Re: import 3d model @Ceciliabr That's interesting, I've been wondering for a while why some textures don't import with .obj files, and now I know! Can you recommend some specific software to do these conversions? I'm not sure what to search for. On a related note, I also have trouble with .3ds files downloaded from the internet not importing textures, even with .png and .jpg texture files. I've read that you have to zip everything in one file, which I've tried, but it still doesn't work. Any tricks on how to make it work? Thanks so much! |
| Posted by Puybaret at Jan 25, 2021, 9:03:47 AM |
Re: import 3d model Zipping imported files with their textures is required only for the Mac App Store version. You may convert with any image handling program, like Gimp bit even tools of your system are generally enough. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GhyslainB at Jan 26, 2021, 2:52:54 AM |
Re: import 3d model Thanks Emmanuel for the clarification. I've now found an online converter for .tga and .dds files (I couldn't open them in Photoshop, apparently) and I managed to import some .obj files that had long resisted me! I'm still stuck with a few .3ds downloaded from free repositories. I see the .3ds and the textures, but no .mtl file; is it missing and therefore it's a hopeless cause? I'll give you a specific example with this fireplace: https://open3dmodel.com/3d-models/fireplace-3d-model-43_4902.html As always, thanks a lot for the help! |
Current timezone is GMT Sep 25, 2026, 7:45:22 AM |
