Print at Sep 30, 2026, 2:10:26 AM
Posted by Texchanchan at Jun 13, 2020, 1:31:46 AM
Floor is raised in photo above real floor height
In the next-to-best photo rendering the floors are all about 2 feet higher than in the original. This gives the impression the room has been partially filled with concrete.
Here is an example of what I mean. Note the stripe down the middle where you can see the depth and texture of the real floor. That stripe is above a wall in the basement - another confusing factor.
Here is what it's really like in there:
Posted by Mike53 at Jun 13, 2020, 11:58:30 AM
Re: Floor is raised in photo above real floor height
it looks like your ceilings in your basement are showing, check the "height" setting in your basement level
Posted by Texchanchan at Jun 13, 2020, 11:53:27 PM
That worked. It also fixed the ceiling height. Thank you.
Posted by Texchanchan at Jun 14, 2020, 12:10:29 AM
oops, wrong photo. Here's a good one.
