Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rooms out of shape after many wall changes |
| Print at Oct 9, 2026, 6:11:40 AM | |
| Posted by stain35 at Jun 13, 2020, 10:26:04 PM |
Rooms out of shape after many wall changes Having done numerous changes in my first project, including recreating walls to ensure different levels are aligned correctly, most of my room shapes are slightly misshaped in relation to the walls. I realise that double clicking in rooms will create the correct shape. However, I have done so much work on my current rooms that I want to alter the shape to fit finalised walls. Attempting this manually by moving points is not great as many extra points have appeared over time. Is there any way of auto-reshaping rooms? Cheers Mark |
| Posted by stain35 at Jun 13, 2020, 10:26:59 PM |
Re: Rooms out of shape after many wall changes I meant to write "I realise that double clicking in walls" |
| Posted by Mike53 at Jun 14, 2020, 9:00:06 PM |
Re: Rooms out of shape after many wall changes If, for some reason, you cannot simply delete the room and then recreate a room that match's your walls automatically, you can left click on you room > right click near each of the points you do not require and from the drop down menu delete point |
| Posted by stain35 at Jun 19, 2020, 5:55:09 PM |
Re: Rooms out of shape after many wall changes Thanks. Deleting points was useful (not done that before) and also did not realise that either double clicking mis-aligned corner points or dragging would automatically re-align with existing walls. Much neater now thanks. |
Current timezone is GMT Oct 9, 2026, 6:11:40 AM |
