Print at Sep 24, 2026, 11:08:49 AM
Posted by Olaf_Noehring at May 15, 2009, 8:57:00 PM
Feat. Req: Automatically measure all walls
Hi
I have used Roomarranger in the past. A great feature there is to automatically measure all walls - saves a lot of work.
Olaf
[Note: this thread was started on sourceforge.net forums]
Posted by c_sanz at May 16, 2009, 12:23:00 PM
Re: Feat. Req: Automatically measure all wall
The tool "Create dimensions" has no dependence on an object, dimensions are totally free, so therefore the magnetism of these does not work on the walls.
This function is not provided in the near future.
Greeting,
Christian.
Posted by mark at May 17, 2009, 9:54:00 AM
Re: Feat. Req: Automatically measure all walls
If "measure" means something like total length of all walls or area wouldn't it be pretty easy to make a plugin and then just run from the menu ? i.e. like volumeplugin.
Something like ....
VolumnePlugin.java
public void execute() {
float volumeInCm3 = 0;
double wallLength = 0;
double totalWallLength = 0;
StringBuffer wallDimensionsMsg = new StringBuffer();
for (Wall wall : getHome().getWalls()){
if (wall.getXStart() == wall.getXEnd()) {
wallLength = wall.getYStart() - wall.getYEnd();
} else if (wall.getYStart() == wall.getYEnd()){
wallLength = wall.getXStart() - wall.getXEnd();
} else {
wallLength = Math.sqrt(Math.pow((wall.getXEnd()-wall.getXStart()),2)
+ (Math.pow((wall.getYEnd() - wall.getYStart()),2)));
// get rid of negative values
wallLength = ((wallLength < 0 ? -wallLength : wallLength));
totalWallLength+=wallLength;
wallDimensionsMsg.append("Wall: length " + wallLength + "\n");
wallDimensionsMsg.append(String.format(" Total wall length = %.2f cm", totalWallLength));
JOptionPane.showMessageDialog(null, wallDimensionsMsg);
Output would be " Total wall length = 1455.00 cm"
Excuse me if I got the wrong end of the stick :)
ta
mark
