Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Trapezoid Window |
| Print at Sep 26, 2026, 6:58:11 AM | |
| Posted by manishlulla at Jul 2, 2020, 12:20:58 PM |
Trapezoid Window Hi All Power Users, I am trying to find how to put trapezoid windows in my model. Need to be able to change the dimensions as each window is a different size. Thank you very much in advance. Manish https://www.pinterest.com/pin/201958983016206...db2jw4cxXTM4HZziSxvjWrFzb[/img] |
| Posted by Mike53 at Jul 2, 2020, 1:00:32 PM |
Re: Trapezoid Window Whether you have made them yourself or downloaded them from elsewhere, during the import process you need to select (checkbox) that the object will be a door or window, once you have done that it should fit correctly into the wall and still enable you to modify the dimensions |
| Posted by manishlulla at Jul 2, 2020, 1:18:01 PM |
Re: Trapezoid Window Hi Mike, Thank you. I am a newbie, didnt follow your note. I want to create a trapezoid window, I cant find a trapezoid window object for SweetHome3D. All windows are square. Thank you. |
| Posted by VeroniQ at Jul 2, 2020, 1:36:13 PM |
Re: Trapezoid Window There were some special windows in this article. Maybe they could feet... |
| Posted by manishlulla at Jul 2, 2020, 4:26:17 PM |
Re: Trapezoid Window Excellent, Thank you very much! Will try these out. |
Current timezone is GMT Sep 26, 2026, 6:58:11 AM |
