Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Modifying dimensions once after they have been added |
| Print at Sep 26, 2026, 3:26:04 PM | |
| Posted by kpachodap at Jul 4, 2020, 1:46:48 PM |
Modifying dimensions once after they have been added I am using Sweet Home 3D 64 bit version for Windows. I am able to add dimensions to my floor plan, but after the dimension is added I do not see any option to select and modify or even delete the dimension. How can I accomplish this? |
| Posted by Puybaret at Jul 4, 2020, 4:52:59 PM |
Re: Modifying dimensions once after they have been added You can modify dimensions only with the mouse. If you want to enter a precise value, type <Enter> when you initially draw it. See included help for more information. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Jul 4, 2020, 4:53:27 PM |
Re: Modifying dimensions once after they have been added Select the dimension with the cursor, hit DEL to delete it. Drag one of the sides to modify it. It is not possible to modify it by typing a different value that autoscales the dimension. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by kpachodap at Jul 5, 2020, 1:41:09 AM |
Re: Modifying dimensions once after they have been added Thanks Hansmex, I was able to do as you advised after unlocking my floor plan. |
| Posted by dorin at Jul 6, 2020, 11:25:29 AM |
Re: Modifying dimensions once after they have been added 1. Install AdvancedEditingPlugin ; 2. Select dimension (or other thing) then click Resizes all selected items... button. I use this frequently to insert more accurate dimensions. Also pay attention to position buttons. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Gildaniel at Jul 8, 2020, 8:10:50 AM |
Re: Modifying dimensions once after they have been added 1. Install AdvancedEditingPlugin ; 2. Select dimension (or other thing) then click Resizes all selected items... button. I use this frequently to insert more accurate dimensions. Also pay attention to position buttons. Bravo!!! |
Current timezone is GMT Sep 26, 2026, 3:26:04 PM |
