Print at Sep 30, 2026, 12:33:11 AM
Posted by bdfd at Jul 5, 2020, 7:39:41 AM
confused   Photo-video rendering plug-in - crash
With none answer, I decided to create this new thread. wink
Pictures are better than words. biggrin
The file :
65 MB compressed.
Night texture in view 3D
The parameters
After launching, sh3d calculates during 10 sec and gives this picture.
1 sec after this picture, SH3D crashes down violently !!!
Why ?
NB : same file at noon = same crash
same file with another texture for the sky = same crash
same file with puybaret's yarafay plugin = same crash...
same file with sunflow method is OK with PVR 1.9
same file with Standard rendering is OK...
Posted by hansmex at Jul 5, 2020, 8:51:12 AM
Re: Photo-video rendering plug-in - crash
Standard procedure for me is:
- Delete half of your models and render. If it renders OK, you know that one of your models is at fault.
- Repeat the process until you have the culprit.
NB: I see a tree in your image. Trees can cause havoc during r endering.
Posted by Puybaret at Jul 5, 2020, 9:09:13 AM
YafaRay is programmed in C++ not in Java, so in case of problem, it might make Sweet Home 3D crash much more easily than a Java library like SunFlow.
Does it work with YafaRay rendering plug-in?
Posted by bdfd at Jul 5, 2020, 9:56:00 AM
Read better... or clean your pair of glasses cool laughing
Posted by Puybaret at Jul 5, 2020, 2:19:26 PM
Then try to make a SH3D as simple as possible that shows the problem and send it to me, because I couldn’t reproduce your issue the last time you mentioned it.
