Print at Sep 26, 2026, 5:45:27 PM
Posted by ryanburkett at Jul 17, 2020, 10:42:21 PM
Trim the end of a curved wall
I designed a curved staircase that is hidden behind a book case. To meet the space requirements, I would like to trim the end off of the curved wall to provide better access to the stairwell. Every time I try to move the endpoint of the wall, the shape changes. How can I do this?
Posted by hansmex at Jul 18, 2020, 6:28:07 AM
Re: Trim the end of a curved wall
There's no easy way to shorten a curved wall. Best you draw a new wall.
Mark starting and end point of your wall.
Delete old wall & draw a new wall from/to the marked points.
Redefine the curve.
Posted by Xiste at Jul 18, 2020, 12:24:15 PM
No need for a new wall.
Imagine the full 360 ° circle of your curved wall. Find out how many degrees you want to shorten it with, and subtract that number from your current arc extent measure. Then your wall will snap into place.
Posted by ryanburkett at Jul 24, 2020, 12:32:38 PM
This worked! Thank you Hans!
Posted by ryanburkett at Jul 24, 2020, 12:33:41 PM
This changed the arc and would not work, but thank you for the attempt!
