Print at Sep 29, 2026, 6:36:49 AM
Posted by basil_battery at Jun 8, 2009, 10:15:00 AM
Imported objects are transparent!
Hello
Every object I import from recommended site (www.archibaseplanet.com) looks transparent on 3D view.
For example, I take this object http://www.archibaseplanet.com/download/16722.html and I see it like this http://s46.radikal.ru/i111/0906/8a/14e8d717c920.jpg
Objects from this site are very useful for me. How can I make them visible?
[Note: this thread was started on sourceforge.net forums]
Posted by Puybaret at Jun 9, 2009, 11:19:00 PM
Re: Imported objects are transparent!
The easiest way with Sweet Home 3D would be to:
- import the model 3D file in an empty home
- export it to OBJ format with "3D view > Export to OBJ format..."
- edit the MTL file generated along with OBJ file with a text editor
- change the transparency line that starts with "d xxx" to "d 1"
- save MTL file
- import the exported OBJ file
Posted by basil_battery at Jun 10, 2009, 12:00:00 PM
OK, It works, thank you
