Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3d shut down after some seconds |
| Print at Sep 27, 2026, 9:03:41 AM | |
| Posted by C_Valanc at Jun 11, 2009, 12:44:00 PM |
SweetHome3d shut down after some seconds When I start "SweetHome3D.exe". The SweetHome3D window is displayed some seconds and then is closed. Same problem with "SweetHome3D.jnlp". But, strangely for me, if I use SweetHome3D-2.0.jar, the software is entirely usable ! First lines of Error files "hs_err_pidxxxx.log" : - With "SweetHome3D.exe", : # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=4088, tid=4016 # # JRE version: 6.0_14-b08 # Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x41084a] # - With "SweetHome3D.jnlp" : # # An unexpected error has been detected by Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=1792, tid=3524 # # Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86) # Problematic frame: # C [atioglxx.dll+0x41084a] # From which is coming this problem (also with 1.6, 1.7, 1.8) ? Thanks. [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Jun 11, 2009, 1:03:00 PM |
Re: SweetHome3d shut down after some seconds One of the differences between the installer/Java Web Start version and the Jar executable version is the max amount of memory required by Sweet Home 3D to run. Please, run SweetHome3D-2.0.jar with the following command (use Windows Start menu > Execute dialog box and replace "C:\path\to\" by the exact location where SweetHome3D-2.0.jar can be found): javaw -Xmx512m -jar C:\path\to\SweetHome3D-2.0.jar then with the following command: javaw -Xmx1024m -jar C:\path\to\SweetHome3D-2.0.jar and report here if both commands worked correctly. Thank you for your help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by C_Valanc at Jun 11, 2009, 3:06:00 PM |
Re: SweetHome3d shut down after some seconds javaw -Xmx512m -jar "C:\Program Files\Sweet Home 3D\SweetHome3D-2.0.jar" It is well. javaw -Xmx1024m -jar "C:\Program Files\Sweet Home 3D\SweetHome3D-2.0.jar" SweetHome3D window is displayed some seconds and then is closed, as for SweetHome3D-2.0.exe and SweetHome3D-2.0.jnlp |
| Posted by Puybaret at Jun 11, 2009, 3:45:00 PM |
Re: SweetHome3d shut down after some seconds Thank you for these tests. It looks like that requesting too much max memory may cause some problems. Could you describe your operating system and confirm that the following JNLP file works: http://www.sweethome3d.eu/SweetHome3D-512MB.jnlp ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by C_Valanc at Jun 11, 2009, 4:58:00 PM |
Re: SweetHome3d shut down after some seconds With the following JNLP file "http://www.sweethome3d.eu/SweetHome3D-512MB.jnlp" the SweetHome3D window is displayed some seconds and then is closed... My Operating System : Microsoft Windows XP Home Edition Service Pack 3 DirectX 4.09.00.0904 (DirectX 9.0c) |
| Posted by Puybaret at Jun 11, 2009, 8:04:00 PM |
Re: SweetHome3d shut down after some seconds Thank you for this information. One last thing if you're ok: Could you try older versions of Sweet Home 3D available at http://sourceforge.net/project/showfiles.php?...568&package_id=245525 , like version 1.8 http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-1.8-windows.exe Maybe they fail also on your computer... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by C_Valanc at Jun 12, 2009, 10:41:00 AM |
Re: SweetHome3d shut down after some seconds I had the same problem after the version 1.4 (the first as I used), with 1.6 and 1.8 in the default directory. Same problem when I install the new version after I had uninstalled the previous version. Only the versions .jar was working. I has just to install the versions 1.5, 1.6, 1.7, 1.8 and 2.0 in different directories. * the versions 1.6, 1.7 and 1.8 run properly, in opposition to my previous tests (an old file not uninstalled ?). * in these same conditions, the version 2.0 starts and then stops after 2 or 3 s. |
| Posted by Puybaret at Jun 13, 2009, 9:50:00 AM |
Re: SweetHome3d shut down after some seconds Thank your for these tests. The behavior of your installations is really strange... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ulundbac at Jun 14, 2009, 9:48:00 PM |
Re: SweetHome3d shut down after some seconds I have exactly the same problem. # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6940161a, pid=516, tid=3728 # # JRE version: 6.0_14-b08 # Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x40161a] # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x472fc800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3728, stack(0x48c20000,0x48c70000)] siginfo: ExceptionCode=0xc0000005, reading address 0x00424000 Registers: EAX=0x48a3d1fc, EBX=0x00000127, ECX=0x00424000, EDX=0x48a3d1fc ESP=0x48c6f3f0, EBP=0x00000004, ESI=0x47b02280, EDI=0x48554428 EIP=0x6940161a, EFLAGS=0x00010202 Top of Stack: (sp=0x48c6f3f0) 0x48c6f3f0: 47b02280 00000000 4859a0d8 48554428 0x48c6f400: 00000000 0000000a 00424000 0000000a 0x48c6f410: 69401440 4859a0d8 6924f3c0 000305dc 0x48c6f420: 3101109e 47b02280 48554428 693f9f0a 0x48c6f430: 48c6f460 00000127 48c6f450 00000008 0x48c6f440: 4859a0d8 472fc910 00000010 00000000 0x48c6f450: 00000000 00000000 00000187 0000011b 0x48c6f460: 00000000 00000000 00000500 00000400 Instructions: (pc=0x6940161a) 0x6940160a: fd 02 8b 4c 24 18 75 08 66 8b 11 66 89 10 eb 04 0x6940161a: 8b 11 89 10 8b 54 24 44 8b 44 24 48 8b 48 08 43 Stack: [0x48c20000,0x48c70000], sp=0x48c6f3f0, free space=316k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [atioglxx.dll+0x40161a] [error occurred during error reporting (printing native stack), id 0xc0000005] Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j javax.media.j3d.NativePipeline.createNewContext(Ljavax/media/j3d/Canvas3D;JJJJZZZZ)J+0 j javax.media.j3d.NativePipeline.createNewContext(Ljavax/media/j3d/Canvas3D;JLjavax/media/j3d/Drawable;JLjavax/media/j3d/Context;ZZZZ)Ljavax/media/j3d/Context;+25 j javax.media.j3d.Canvas3D.createNewContext(JLjavax/media/j3d/Drawable;JLjavax/media/j3d/Context;ZZZZ)Ljavax/media/j3d/Context;+18 j javax.media.j3d.Canvas3D.createNewContext(Ljavax/media/j3d/Context;Z)Ljavax/media/j3d/Context;+36 J javax.media.j3d.Renderer.doWork(J)V j javax.media.j3d.J3dThread.run()V+19 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0x4785e800 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=1264, stack(0x49480000,0x494d0000)] 0x4785d400 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=3624, stack(0x49430000,0x49480000)] 0x47847400 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=3616, stack(0x493e0000,0x49430000)] 0x47848800 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=3612, stack(0x49390000,0x493e0000)] 0x47841c00 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=3272, stack(0x49340000,0x49390000)] 0x47840800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=4016, stack(0x492f0000,0x49340000)] 0x4783f800 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=3492, stack(0x492a0000,0x492f0000)] 0x4783e800 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=3580, stack(0x49250000,0x492a0000)] 0x4783e400 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=524, stack(0x48ec0000,0x48f10000)] 0x4784a400 JavaThread "pool-7-thread-1" [_thread_blocked, id=3508, stack(0x49180000,0x491d0000)] 0x47816400 JavaThread "pool-6-thread-2" [_thread_blocked, id=3504, stack(0x49130000,0x49180000)] 0x4781a800 JavaThread "pool-6-thread-1" [_thread_blocked, id=3852, stack(0x490e0000,0x49130000)] 0x4723f800 JavaThread "pool-4-thread-4" [_thread_blocked, id=3548, stack(0x49090000,0x490e0000)] 0x47241000 JavaThread "pool-4-thread-3" [_thread_blocked, id=2000, stack(0x49040000,0x49090000)] 0x4723e000 JavaThread "pool-4-thread-2" [_thread_blocked, id=3836, stack(0x48ff0000,0x49040000)] 0x4723d400 JavaThread "pool-4-thread-1" [_thread_blocked, id=3432, stack(0x47640000,0x47690000)] 0x4737b000 JavaThread "TimerQueue" daemon [_thread_blocked, id=576, stack(0x48f10000,0x48f60000)] 0x46ead400 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=3284, stack(0x48e70000,0x48ec0000)] 0x4734e400 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3268, stack(0x48e20000,0x48e70000)] 0x003f6800 JavaThread "DestroyJavaVM" [_thread_blocked, id=760, stack(0x008d0000,0x00920000)] =>0x472fc800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=3728, stack(0x48c20000,0x48c70000)] 0x47333400 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=2964, stack(0x48690000,0x486e0000)] 0x47306800 JavaThread "J3D-NotificationThread" [_thread_blocked, id=1932, stack(0x48640000,0x48690000)] 0x472f6800 JavaThread "J3D-TimerThread" [_thread_blocked, id=2736, stack(0x483c0000,0x48410000)] 0x4732f400 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=3148, stack(0x48370000,0x483c0000)] 0x4727c400 JavaThread "pool-2-thread-1" [_thread_in_native, id=1844, stack(0x47690000,0x476e0000)] 0x47271400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=3736, stack(0x475f0000,0x47640000)] 0x47260c00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1944, stack(0x47550000,0x475a0000)] 0x472a2000 JavaThread "AWT-Shutdown" [_thread_blocked, id=2944, stack(0x47500000,0x47550000)] 0x46ed4800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3740, stack(0x47460000,0x474b0000)] 0x46ea0c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2708, stack(0x470f0000,0x47140000)] 0x46e9a800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2696, stack(0x470a0000,0x470f0000)] 0x46e98c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=2168, stack(0x47050000,0x470a0000)] 0x46e97c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2672, stack(0x47000000,0x47050000)] 0x46e87c00 JavaThread "Finalizer" daemon [_thread_blocked, id=1324, stack(0x46fb0000,0x47000000)] 0x46e83000 JavaThread "Reference Handler" daemon [_thread_blocked, id=880, stack(0x46f60000,0x46fb0000)] Other Threads: 0x46e80000 VMThread [stack: 0x46f10000,0x46f60000] [id=2668] 0x46ea2c00 WatcherThread [stack: 0x47140000,0x47190000] [id=2172] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 3200K, used 844K [0x029d0000, 0x02d40000, 0x07890000) eden space 2880K, 18% used [0x029d0000, 0x02a53138, 0x02ca0000) from space 320K, 100% used [0x02cf0000, 0x02d40000, 0x02d40000) to space 320K, 0% used [0x02ca0000, 0x02ca0000, 0x02cf0000) tenured generation total 40684K, used 30282K [0x07890000, 0x0a04b000, 0x429d0000) the space 40684K, 74% used [0x07890000, 0x096229e0, 0x09622a00, 0x0a04b000) compacting perm gen total 16384K, used 16376K [0x429d0000, 0x439d0000, 0x469d0000) the space 16384K, 99% used [0x429d0000, 0x439ce2a8, 0x439ce400, 0x439d0000) No shared spaces configured. Dynamic libraries: 0x00400000 - 0x00424000 C:\Program Files\Sweet Home 3D\jre6\launch4j-tmp\SweetHome3D.exe 0x7c900000 - 0x7c9b2000 C:\WINDOWS\system32\ntdll.dll 0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll 0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll 0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll 0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll 0x7e410000 - 0x7e4a1000 C:\WINDOWS\system32\USER32.dll 0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll 0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL 0x7c340000 - 0x7c396000 C:\Program Files\Sweet Home 3D\jre6\bin\msvcr71.dll 0x6d800000 - 0x6da8b000 C:\Program Files\Sweet Home 3D\jre6\bin\client\jvm.dll 0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll 0x6d7b0000 - 0x6d7bc000 C:\Program Files\Sweet Home 3D\jre6\bin\verify.dll 0x6d330000 - 0x6d34f000 C:\Program Files\Sweet Home 3D\jre6\bin\java.dll 0x6d290000 - 0x6d298000 C:\Program Files\Sweet Home 3D\jre6\bin\hpi.dll 0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL 0x6d7f0000 - 0x6d7ff000 C:\Program Files\Sweet Home 3D\jre6\bin\zip.dll 0x6d610000 - 0x6d623000 C:\Program Files\Sweet Home 3D\jre6\bin\net.dll 0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll 0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll 0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll 0x71a50000 - 0x71a8f000 C:\WINDOWS\system32\mswsock.dll 0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll 0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll 0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll 0x769c0000 - 0x76a74000 C:\WINDOWS\system32\USERENV.dll 0x5b860000 - 0x5b8b5000 C:\WINDOWS\system32\netapi32.dll 0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll 0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll 0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll 0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll 0x6d000000 - 0x6d14a000 C:\Program Files\Sweet Home 3D\jre6\bin\awt.dll 0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV 0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll 0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll 0x6d450000 - 0x6d474000 C:\Program Files\Sweet Home 3D\jre6\bin\jpeg.dll 0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll 0x6d230000 - 0x6d284000 C:\Program Files\Sweet Home 3D\jre6\bin\fontmanager.dll 0x74720000 - 0x7476c000 C:\WINDOWS\system32\MSCTF.dll 0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime 0x4fdd0000 - 0x4ff76000 C:\WINDOWS\system32\d3d9.dll 0x475e0000 - 0x475e6000 C:\WINDOWS\system32\d3d8thk.dll 0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll 0x47ae0000 - 0x47aee000 C:\Program Files\Sweet Home 3D\lib\j3dcore-ogl-chk.dll 0x5ed00000 - 0x5edcc000 C:\WINDOWS\system32\OPENGL32.dll 0x68b20000 - 0x68b40000 C:\WINDOWS\system32\GLU32.dll 0x73760000 - 0x737ab000 C:\WINDOWS\system32\DDRAW.dll 0x73bc0000 - 0x73bc6000 C:\WINDOWS\system32\DCIMAN32.dll 0x69000000 - 0x69657000 C:\WINDOWS\system32\atioglxx.dll 0x6d360000 - 0x6d366000 C:\Program Files\Sweet Home 3D\jre6\bin\jawt.dll 0x48320000 - 0x48349000 C:\Program Files\Sweet Home 3D\lib\j3dcore-ogl.dll 0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\shell32.dll 0x6d630000 - 0x6d639000 C:\Program Files\Sweet Home 3D\jre6\bin\nio.dll 0x6d1a0000 - 0x6d1c3000 C:\Program Files\Sweet Home 3D\jre6\bin\dcpr.dll VM Arguments: jvm_args: -Djava.library.path=lib -Xmx1024m java_command: com.eteks.sweethome3d.SweetHome3D -open C:\Documents and Settings\Owner\My Documents\Schack\VSK\Schackklubben.sh3d Launcher Type: SUN_STANDARD Environment Variables: PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\Python22;C:\Program Files\PC-Doctor for Windows\services;C:\Program Files\ATI Technologies\ATI Control Panel;C:\PROGRA~1\ABSOLU~1;C:\Program Files\IDM Computer Solutions\UltraEdit-32;C:\Program Files\Sweet Home 3D\jre6\bin USERNAME=Owner OS=Windows_NT PROCESSOR_IDENTIFIER=x86 Family 15 Model 3 Stepping 4, GenuineIntel --------------- S Y S T E M --------------- OS: Windows XP Build 2600 Service Pack 3 CPU:total 2 (1 cores per cpu, 2 threads per core) family 15 model 3 stepping 4, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ht Memory: 4k page, physical 523564k(14776k free), swap 1276808k(811224k free) vm_info: Java HotSpot(TM) Client VM (14.0-b16) for windows-x86 JRE (1.6.0_14-b08), built on May 21 2009 08:03:56 by "java_re" with MS VC++ 7.1 time: Sun Jun 14 10:27:24 2009 elapsed time: 21 seconds |
| Posted by Puybaret at Jun 15, 2009, 8:25:00 AM |
Re: SweetHome3d shut down after some seconds Does the Jar file mentioned by cvalanc work for you also? Please read also Sweet Home 3D FAQ at http://www.sweethome3d.eu/faq.html ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kompa3 at Jul 31, 2009, 9:16:00 PM |
Re: SweetHome3d shut down after some seconds I have exactly the same problem. A fresh installation of the software, no previous installations exist. The 512MB link worked well. The log is as follows: # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x69411bbe, pid=3388, tid=3496 # # JRE version: 6.0_14-b08 # Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x411bbe] # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x46eba400): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3496, stack(0x49c90000,0x49ce0000)] siginfo: ExceptionCode=0xc0000005, reading address 0x0035efac Registers: EAX=0x4a9e0020, EBX=0x00000000, ECX=0x0035efac, EDX=0x00000000 ESP=0x49cdf65c, EBP=0x00000004, ESI=0x4f6d8d68, EDI=0x4a9e0020 EIP=0x69411bbe, EFLAGS=0x00010202 Top of Stack: (sp=0x49cdf65c) 0x49cdf65c: 4f6d8d68 00000000 497dc0d8 4f7db008 0x49cdf66c: 007dc008 00000000 0035efac 00000000 0x49cdf67c: 00000000 00000000 00001900 00000200 0x49cdf68c: 00000100 00000000 000008c0 69408b8a 0x49cdf69c: 49cdf6cc 4f7db008 49cdf6bc 00000008 0x49cdf6ac: 497dc0d8 46eba510 00000010 00000000 0x49cdf6bc: 00000000 00000000 0000022d 00000195 0x49cdf6cc: 00000000 00000000 00000640 000004b0 Instructions: (pc=0x69411bbe) 0x69411bae: fd 02 8b 4c 24 18 75 08 66 8b 11 66 89 10 eb 04 0x69411bbe: 8b 11 89 10 8b 4c 24 20 8b 44 24 34 8b 7c 24 24 Stack: [0x49c90000,0x49ce0000], sp=0x49cdf65c, free space=317k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [atioglxx.dll+0x411bbe] [error occurred during error reporting (printing native stack), id 0xc0000005] Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j javax.media.j3d.NativePipeline.createNewContext(Ljavax/media/j3d/Canvas3D;JJJJZZZZ)J+0 j javax.media.j3d.NativePipeline.createNewContext(Ljavax/media/j3d/Canvas3D;JLjavax/media/j3d/Drawable;JLjavax/media/j3d/Context;ZZZZ)Ljavax/media/j3d/Context;+25 j javax.media.j3d.Canvas3D.createNewContext(JLjavax/media/j3d/Drawable;JLjavax/media/j3d/Context;ZZZZ)Ljavax/media/j3d/Context;+18 j javax.media.j3d.Canvas3D.createNewContext(Ljavax/media/j3d/Context;Z)Ljavax/media/j3d/Context;+36 j javax.media.j3d.Renderer.doWork(J)V+3729 j javax.media.j3d.J3dThread.run()V+19 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0x4a085800 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=2788, stack(0x4a8b0000,0x4a900000)] 0x4730ac00 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=3188, stack(0x4a860000,0x4a8b0000)] 0x47256800 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=3196, stack(0x4a810000,0x4a860000)] 0x4a089800 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=3200, stack(0x4a7c0000,0x4a810000)] 0x4a09f000 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=3400, stack(0x4a770000,0x4a7c0000)] 0x4a1eb400 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=3540, stack(0x4a720000,0x4a770000)] 0x4a19d400 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=3488, stack(0x4a6d0000,0x4a720000)] 0x4a1d6c00 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=3212, stack(0x4a680000,0x4a6d0000)] 0x4a1b3400 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=3208, stack(0x47620000,0x47670000)] 0x4724a800 JavaThread "Image Fetcher 3" daemon [_thread_blocked, id=3532, stack(0x4a430000,0x4a480000)] 0x4731e400 JavaThread "Image Fetcher 2" daemon [_thread_blocked, id=3480, stack(0x4a3e0000,0x4a430000)] 0x46eb6800 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=3476, stack(0x49f60000,0x49fb0000)] 0x47353c00 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3500, stack(0x49f10000,0x49f60000)] 0x00846800 JavaThread "DestroyJavaVM" [_thread_blocked, id=1340, stack(0x008e0000,0x00930000)] =>0x46eba400 JavaThread "J3D-Renderer-1" [_thread_in_native, id=3496, stack(0x49c90000,0x49ce0000)] 0x46f1d400 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=3536, stack(0x49c30000,0x49c80000)] 0x471a0800 JavaThread "J3D-NotificationThread" [_thread_blocked, id=3520, stack(0x49be0000,0x49c30000)] 0x46f18400 JavaThread "J3D-TimerThread" [_thread_blocked, id=3504, stack(0x49b90000,0x49be0000)] 0x46ec4400 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=3492, stack(0x49b40000,0x49b90000)] 0x4728bc00 JavaThread "pool-2-thread-1" [_thread_in_native, id=3484, stack(0x47670000,0x476c0000)] 0x4727bc00 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=1068, stack(0x475d0000,0x47620000)] 0x47273800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1044, stack(0x47540000,0x47590000)] 0x472b3c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=3340, stack(0x474f0000,0x47540000)] 0x47265000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=992, stack(0x47450000,0x474a0000)] 0x46eb0c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3468, stack(0x47100000,0x47150000)] 0x46eaa800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3332, stack(0x470b0000,0x47100000)] 0x46ea9000 JavaThread "Attach Listener" daemon [_thread_blocked, id=3336, stack(0x47060000,0x470b0000)] 0x46ea7c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3344, stack(0x47010000,0x47060000)] 0x46e97c00 JavaThread "Finalizer" daemon [_thread_blocked, id=3372, stack(0x46fc0000,0x47010000)] 0x46e93000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3084, stack(0x46f70000,0x46fc0000)] Other Threads: 0x46e90000 VMThread [stack: 0x46f20000,0x46f70000] [id=712] 0x46ebc400 WatcherThread [stack: 0x47150000,0x471a0000] [id=3364] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 960K, used 578K [0x029e0000, 0x02ae0000, 0x078a0000) eden space 896K, 57% used [0x029e0000, 0x02a60be0, 0x02ac0000) from space 64K, 100% used [0x02ac0000, 0x02ad0000, 0x02ad0000) to space 64K, 0% used [0x02ad0000, 0x02ad0000, 0x02ae0000) tenured generation total 9232K, used 7554K [0x078a0000, 0x081a4000, 0x429e0000) the space 9232K, 81% used [0x078a0000, 0x08000b40, 0x08000c00, 0x081a4000) compacting perm gen total 15616K, used 15433K [0x429e0000, 0x43920000, 0x469e0000) the space 15616K, 98% used [0x429e0000, 0x438f2408, 0x438f2600, 0x43920000) No shared spaces configured. Dynamic libraries: 0x00400000 - 0x00424000 C:\Program Files\Sweet Home 3D\jre6\launch4j-tmp\SweetHome3D.exe 0x7c900000 - 0x7c9b1000 C:\WINDOWS\system32\ntdll.dll 0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll 0x77dc0000 - 0x77e6a000 C:\WINDOWS\system32\ADVAPI32.dll 0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll 0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll 0x7e360000 - 0x7e3f1000 C:\WINDOWS\system32\USER32.dll 0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll 0x76370000 - 0x7638d000 C:\WINDOWS\system32\IMM32.DLL 0x62f30000 - 0x62f39000 C:\WINDOWS\system32\LPK.DLL 0x75550000 - 0x755bb000 C:\WINDOWS\system32\USP10.dll 0x7c340000 - 0x7c396000 C:\Program Files\Sweet Home 3D\jre6\bin\msvcr71.dll 0x6d800000 - 0x6da8b000 C:\Program Files\Sweet Home 3D\jre6\bin\client\jvm.dll 0x76b30000 - 0x76b5d000 C:\WINDOWS\system32\WINMM.dll 0x6d7b0000 - 0x6d7bc000 C:\Program Files\Sweet Home 3D\jre6\bin\verify.dll 0x6d330000 - 0x6d34f000 C:\Program Files\Sweet Home 3D\jre6\bin\java.dll 0x6d290000 - 0x6d298000 C:\Program Files\Sweet Home 3D\jre6\bin\hpi.dll 0x76be0000 - 0x76beb000 C:\WINDOWS\system32\PSAPI.DLL 0x6d7f0000 - 0x6d7ff000 C:\Program Files\Sweet Home 3D\jre6\bin\zip.dll 0x6d610000 - 0x6d623000 C:\Program Files\Sweet Home 3D\jre6\bin\net.dll 0x71aa0000 - 0x71ab7000 C:\WINDOWS\system32\WS2_32.dll 0x77c00000 - 0x77c58000 C:\WINDOWS\system32\msvcrt.dll 0x71a90000 - 0x71a98000 C:\WINDOWS\system32\WS2HELP.dll 0x71a40000 - 0x71a80000 C:\WINDOWS\system32\mswsock.dll 0x698d0000 - 0x69928000 C:\WINDOWS\system32\hnetcfg.dll 0x71a80000 - 0x71a88000 C:\WINDOWS\System32\wshtcpip.dll 0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll 0x769b0000 - 0x76a65000 C:\WINDOWS\system32\USERENV.dll 0x60970000 - 0x609c5000 C:\WINDOWS\system32\netapi32.dll 0x76f10000 - 0x76f37000 C:\WINDOWS\system32\DNSAPI.dll 0x76fa0000 - 0x76fa8000 C:\WINDOWS\System32\winrnr.dll 0x76f50000 - 0x76f7d000 C:\WINDOWS\system32\WLDAP32.dll 0x473c0000 - 0x473e5000 C:\Program Files\Bonjour\mdnsNSP.dll 0x76d50000 - 0x76d69000 C:\WINDOWS\system32\Iphlpapi.dll 0x76fb0000 - 0x76fb6000 C:\WINDOWS\system32\rasadhlp.dll 0x6d000000 - 0x6d14a000 C:\Program Files\Sweet Home 3D\jre6\bin\awt.dll 0x72fd0000 - 0x72ff6000 C:\WINDOWS\system32\WINSPOOL.DRV 0x774d0000 - 0x7760d000 C:\WINDOWS\system32\ole32.dll 0x773c0000 - 0x774c3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll 0x6d450000 - 0x6d474000 C:\Program Files\Sweet Home 3D\jre6\bin\jpeg.dll 0x5b2a0000 - 0x5b2d8000 C:\WINDOWS\system32\uxtheme.dll 0x6d230000 - 0x6d284000 C:\Program Files\Sweet Home 3D\jre6\bin\fontmanager.dll 0x746f0000 - 0x7473c000 C:\WINDOWS\system32\MSCTF.dll 0x751a0000 - 0x751ce000 C:\WINDOWS\system32\msctfime.ime 0x69000000 - 0x69678000 C:\WINDOWS\system32\atioglxx.dll 0x476d0000 - 0x476de000 C:\Program Files\Sweet Home 3D\lib\j3dcore-ogl-chk.dll 0x5f250000 - 0x5f31c000 C:\WINDOWS\system32\OPENGL32.dll 0x61560000 - 0x61581000 C:\WINDOWS\system32\GLU32.dll 0x73730000 - 0x7377b000 C:\WINDOWS\system32\DDRAW.dll 0x73b90000 - 0x73b96000 C:\WINDOWS\system32\DCIMAN32.dll 0x6d360000 - 0x6d366000 C:\Program Files\Sweet Home 3D\jre6\bin\jawt.dll 0x49b00000 - 0x49b29000 C:\Program Files\Sweet Home 3D\lib\j3dcore-ogl.dll 0x7c9c0000 - 0x7d1d8000 C:\WINDOWS\system32\shell32.dll 0x6d630000 - 0x6d639000 C:\Program Files\Sweet Home 3D\jre6\bin\nio.dll 0x6d1a0000 - 0x6d1c3000 C:\Program Files\Sweet Home 3D\jre6\bin\dcpr.dll VM Arguments: jvm_args: -Djava.library.path=lib -Xmx1024m java_command: com.eteks.sweethome3d.SweetHome3D Launcher Type: SUN_STANDARD Environment Variables: CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip PATH=C:\Program Files\PHP\;C:\Program Files\PC Connectivity Solution\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\GTK\2.0\bin;C:\Program Files\VDMSound;C:\Program Files\MySQL\MySQL Server 5.0\bin;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\TortoiseSVN\bin;C:\Program Files\QuickTime\QTSystem\;;C:\PROGRA~1\COMMON~1\MUVEET~1\030625;C:\Program Files\Sweet Home 3D\jre6\bin USERNAME=Tommi OS=Windows_NT PROCESSOR_IDENTIFIER=x86 Family 15 Model 44 Stepping 2, AuthenticAMD --------------- S Y S T E M --------------- OS: Windows XP Build 2600 Service Pack 3 CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 44 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext Memory: 4k page, physical 1048048k(402120k free), swap 2520316k(1872172k free) vm_info: Java HotSpot(TM) Client VM (14.0-b16) for windows-x86 JRE (1.6.0_14-b08), built on May 21 2009 08:03:56 by "java_re" with MS VC++ 7.1 time: Fri Jul 31 21:56:15 2009 elapsed time: 12 seconds |
| Posted by Puybaret at Aug 6, 2009, 6:50:00 PM |
Re: SweetHome3d shut down after some seconds I'll roll back max memory to 512 MB to avoid "could not create the Java virtual machine" errors under Windows in next release. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by danuntu at Aug 27, 2010, 6:28:53 AM |
Re: SweetHome3d shut down after some seconds My problem is similiar to the following thread with the exception that i use linux. Kubuntu 10.04 LTS to be exact. I have an older version of SweetHome 3D running on another linux box and it runs fine. But this one the the program opens for maybe a second then closes. Why?!? I've updated my Java to Suns JRE 6 update 21. but still no SweetHome. Thanks, D When I start "SweetHome3D.exe". The SweetHome3D window is displayed some seconds and then is closed. Same problem with "SweetHome3D.jnlp". But, strangely for me, if I use SweetHome3D-2.0.jar, the software is entirely usable ! First lines of Error files "hs_err_pidxxxx.log" : - With "SweetHome3D.exe", : # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=4088, tid=4016 # # JRE version: 6.0_14-b08 # Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x41084a] # - With "SweetHome3D.jnlp" : # # An unexpected error has been detected by Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=1792, tid=3524 # # Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86) # Problematic frame: # C [atioglxx.dll+0x41084a] # From which is coming this problem (also with 1.6, 1.7, 1.8) ? Thanks. [Note: this thread was started on sourceforge.net forums] |
| Posted by hansmex at Aug 27, 2010, 4:43:20 PM |
Re: SweetHome3d shut down after some seconds Daniel, I'm not sure what all that text in the logs means as I'm not a computer expert. However, I use Ubuntu 10.04 and I don't have (m)any problems with SH3D. From reading this forum I have noticed that many, MANY problems with SH3D are being caused by (incompatible) video drivers/cards. I notice in your log files the lines: # Problematic frame:My suggestion would be to try to update your video drivers. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by danuntu at Aug 27, 2010, 7:19:06 PM |
Re: SweetHome3d shut down after some seconds My apologies. The quote that i inserted was not from my computer. That was from C_Valanc's post in '09. I haven't found any error log in kubuntu or for SH3D. It just simply closes after a second or so. D |
| Posted by danuntu at Aug 28, 2010, 4:09:21 AM |
Re: SweetHome3d shut down after some seconds UPDATE.... I installed SH3D on another kubuntu box and it works fine. It could be the graphics card but for now i've got to used it as is. Thanks, D |
| Posted by Alabdali at Oct 23, 2015, 8:49:07 PM |
Re: SweetHome3d shut down after some seconds I got problem when I update the window from 7 to window 10 err 1114 DLL |
Current timezone is GMT Sep 27, 2026, 9:03:41 AM |
