Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Error in sh3d 6.4 with old projects ? |
| Print at Sep 25, 2026, 11:02:12 PM |
| Posted by bdfd at Jul 31, 2020, 1:27:19 PM |
Error in sh3d 6.4 with old projects ? Hi, I saw a problem with the new version 6.4 and the old projects (<= 6.3). In the given project, open it and try to join wall 1 and wall 2... a problem ? Link Try to join wall 1 and wall 3... no problem !!! strange. NB : the base (Lvl 1) hasn't this problem, only the Lvl 2. Why ? Remark: this project has simple walls and 3 texts box, there is no object and the compressed file weights 1.94 MB. Why ? I didn't see any problem with new file (6.4). ![]() . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Jul 31, 2020, 3:02:12 PM |
Re: Error in sh3d 6.4 with old projects ? The error happens in version 6.3. Very strangely, the wall 2 is joined to itself at its start. I wonder how that could happen, and if you find a way to reproduce this issue, I would be happy to know it so I can fix it. The size of your SH3D file comes from the texture image you used for the ground. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Jul 31, 2020, 5:52:41 PM |
Re: Error in sh3d 6.4 with old projects ? The error happens in version 6.3. Very strangely, the wall 2 is joined to itself at its start. I wonder how that could happen, and if you find a way to reproduce this issue, I would be happy to know it so I can fix it. Like I said, I updated an old project (6.1.2) and I saved it under 6.4.I closed sh3d then I re-opened the project, the walls (not all) became unjoined... The size of your SH3D file comes from the texture image you used for the ground. OK, TY. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Jul 31, 2020, 6:35:34 PM |
Re: Error in sh3d 6.4 with old projects ? Like I said, I updated an old project (6.1.2) and I saved it under 6.4. Hum, it's not what I read I closed sh3d then I re-opened the project, the walls (not all) became unjoined... I just tried to reproduce your issue on a file created with version 6.1.2, but opening, saving and reopening it with version 6.4 didn't show any unjoined wall. There must be something else... ![]() As the version 6.4 introduced more IDs on plan objects, I hope I didn't introduce a bug in the management of existing wall IDs. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Aug 1, 2020, 10:34:48 AM |
Re: Error in sh3d 6.4 with old projects ? Apparently, the error is on a particular project. I tested another old projects and they work fine in 6.4. Mystery of softwares... ![]() . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Aug 2, 2020, 10:06:24 AM |
Re: Error in sh3d 6.4 with old projects ? If ever you kept a copy of the SH3D file before you updated in Sweet Home 3D 6.4, I'll be happy to review it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Aug 3, 2020, 7:54:15 PM |
Re: Error in sh3d 6.4 with old projects ? If ever you kept a copy of the SH3D file before you updated in Sweet Home 3D 6.4, I'll be happy to review it. OK, asap.New : Some errors go on in new project in version 6.4 !!! Again in joined walls which became unjoined after re-opening the file ??? . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by bdfd at Aug 6, 2020, 5:58:18 AM |
Re: Error in sh3d 6.4 with old projects ? In waiting the update of 6.4, I return back to 6.1.2 ! . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Aug 7, 2020, 6:29:24 PM |
Re: Error in sh3d 6.4 with old projects ? I found the bug which happens when a wall is split in two walls, either with Plan > Split wall menu item or when you request to recompute walls in room modification dialog box. I fixed it and will probably release a version 6.4.2 soon. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Aug 8, 2020, 9:29:58 PM |
Re: Error in sh3d 6.4 with old projects ? The version 6.4.2 was released tonight to fix this issue. This update won't join again detached walls, but at least, it will let you join them again and won't provoke this bad bug. Thanks for reporting it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 11:02:12 PM |
