Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I need help with a complex roof |
| Print at Oct 11, 2026, 11:22:33 AM |
| Posted by Shralen at Aug 4, 2020, 9:00:44 PM |
I need help with a complex roofI started working on the house roof yesterday. At first, I made the magenta wall on the first floor and dived it so I could make a triangle. But then I wondered: Would I still be able to customize my room? So today I started over, I made the first floor slop and then added the white triangle on an extra level. ![]() In case the image broke: https://sta.sh/01hgzyswmkzs Not pretty right?... So I tested something, I made the triangle but starting from the first floor, to see if I could customize it. ![]() In case the image broke: https://sta.sh/041fbjvgkxe As I thought the pink carry over the other wall and ceiling... I just want the carpeted room to be pink not the rest. So as you see I have no idea how to make my triangular wall. I need help with this. If you need more explanation on this house you can go on my other topic: http://www.sweethome3d.com/support/forum/viewthread_thread,10436 If you have any question feel free to ask. ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Shralen at Aug 7, 2020, 9:11:24 PM |
Re: I need help with a complex roof So I'm still trying to figure out how to make my inclined walls. But here an update: Front: In case the image broke:https://sta.sh/0u1hfcz1qdt Back: In case the image broke: https://sta.sh/01tjvnb1di49 I'm not 100% happy with this, but it looks better. I'm having a hard time figuring how to my inclined walls look nice... ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Shralen at Aug 11, 2020, 8:50:09 PM |
Re: I need help with a complex roof So... Yeah I'm still trying to understand how to make my slope. So I made some 'fake' roof to see if it would work and all. In case the image broke: https://sta.sh/029q3b6ismvz It still doesn't fit... so I guess I have to make the Cyan higher? Or edit the part of the first flor that pops out? ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by VeroniQ at Aug 12, 2020, 12:07:27 PM |
Re: I need help with a complex roof Example 15 of the Sweet Home 3D Gallery has got a complex roof a little bit like that. Did you have a look at its file? |
| Posted by Shralen at Aug 14, 2020, 6:44:47 PM |
Re: I need help with a complex roof Thanx for the tip, I'll study that house file. ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Mike53 at Aug 14, 2020, 7:31:09 PM |
Re: I need help with a complex roof Hi Shralen HERE is a zip file that contains 2 projects and some screen shots, hopefully you can use them to help you understand how the roof panels can be made with the shape generator tool and also the way to use rooms to help create your wall colouring's. You will see that some of the walls are joined and some are not. Good luck Mike |
| Posted by Shralen at Aug 17, 2020, 6:12:49 PM |
Re: I need help with a complex roof Thank Mike. I tried the generator tool, it would be perfect if I wanted my roof the same format as my room, but I want it to exceed said room. Such as: ![]() In case the image broke: https://sta.sh/0cs3lkt0pip I used the square for this example. Also is there a way to get notified when someone answers our tread/us? ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Shralen at Aug 19, 2020, 7:30:18 PM |
Re: I need help with a complex roof Once more I tried things with a 'fake' roof, by using the square and triangle. Front: ![]() In case the image broke: https://sta.sh/0dnlmiza1ox Back: ![]() In case the image broke: https://sta.sh/01tpmtrtgpc5 It is far from perfect, but it gives you an idea of what I'm trying to do. I did try the shape generator tool, but since I want my shape to exceed the house it is not that easy. I'm not that good in math so it is getting quite complex to make the roof... ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Gildaniel at Aug 24, 2020, 12:09:38 PM |
Re: I need help with a complex roof Hi! You can make complex roof with walls and this feature http://www.sweethome3d.com/support/forum/viewthread_thread,3242 Draw wall on base level, ajust start and end height, add windows if needed Copy as a new furniture and paste, then you can adjust angle |
| Posted by Shralen at Aug 28, 2020, 7:11:47 PM |
Re: I need help with a complex roof I actually managed to make 3 roofs with the shape generator tool. ![]() In case the image broke: https://sta.sh/03jwc9ub91c I send Mike53 the .sh3d file, they said they would try to help me. We'll see if we can figure out how to do the rest. ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
Current timezone is GMT Oct 11, 2026, 11:22:33 AM |
