Print at Oct 16, 2026, 10:39:38 PM
Posted by jrmobile at Aug 16, 2020, 2:40:40 PM
Check if item is selected.
Good day everyone.
Spent hours in developers guide, trying to find out, how do check in plugin if PieceOfFurniture is selected.
Found only getSelectedItems() method, but maybe there is easier way to check it, intead of checking, if my items are in group?
If there is no easier way, would you be so kind to show me the exact code to check if items are in selected group. I'm not expert in java, so would really appreciate it.
Anyway thanks in advance.
Posted by jrmobile at Aug 16, 2020, 11:04:17 PM
Re: Check if item is selected.
I'm trying this way
List<selectableItem> selectedItems = home.getSelectedItems();
List<HomePieceOfFurniture> furniture = selectedItems.getFurniture();
But it fires an error selectableItem cannot be resolved to a type. Same with type "Selectable".
Posted by Puybaret at Aug 17, 2020, 2:57:03 PM
There’s no easier way, because there’s no getParent method in HomePieceOfFurniture class. You’ll have to find the group of each selected item when it doesn’t belong to the list returned by home.getFurniture().
Posted by jrmobile at Aug 17, 2020, 6:43:52 PM
Emmanuel, Thank you very much for your reply.
I know that it is very brazenly, but i ask you to help in making a code piece to obtain a list за selected furniture, by the algorithm you've described?
Posted by jrmobile at Aug 17, 2020, 7:02:45 PM
I'm trying this one, but it still fires an error selectable
List<Selectable> selectedItems = home.getSelectedItems();
for (HomePieceOfFurniture homePiece : furniture) {
if (selectedItems.contains(homepiece)) {
continue;
Posted by jrmobile at Aug 17, 2020, 10:35:44 PM
I've made it. Thanks for your help.
