Print at Oct 8, 2026, 6:54:40 PM
Posted by KostasP at Aug 21, 2020, 4:48:24 AM
DWG to OBJ
Greetings,
I had a friend create a file in Inventor then export it OBJ, I have attempted to imported the OBJ FILE to SweetHome with no luck.
# WaveFront *.obj file (generated by Autodesk ATF)
I am not sure how to attach the file for view on the thread.
Any help would be appreciated.
Regards
Kostas
Posted by Puybaret at Aug 22, 2020, 2:28:00 PM
Re: DWG to OBJ
You should be able to attach a file now.
Posted by KostasP at Aug 23, 2020, 3:03:16 AM
Re: DWG to OBJ
Thank you. We managed to make it work.
I used the zip file that was sent later.
Kind regards
Kostas
