Print at Sep 28, 2026, 10:13:26 AM
Posted by Witold_Krakowski at Jun 25, 2009, 3:00:00 PM
No 3D view in 2.0
I upgraded SweetHome to version 2.0 and now there is no 3D view of my previously created projects. What's wrong? Am I missing something?
[Note: this thread was started on sourceforge.net forums]
Posted by Puybaret at Jun 27, 2009, 6:32:00 PM
Re: No 3D view in 2.0
Miserably, you seem not to be alone. :-(
As proposed by aperezm in https://sourceforge.net/tracker/?func=detail&...id=152568&atid=784665 try to run Sweet Home 3D from its Jar file by following these instructions:
1. Install Java at http://java.com if you didn't already
2. Download http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-2.0.jar
3. Open a run dialog from Windows Start menu > Run...
4. Type the following command in one line:
javaw -Xmx512m -Dsun.java2d.opengl=false -Dsun.java2d.d3d=true -Dsun.java2d.noddraw=false -Dsun.java2d.ddoffscreen=true -Dsun.java2d.ddscale=true -Dj3d.rend=d3d -jar \path\to\SweetHome3D-2.0.jar
(replace "\path\to" by the real path where the file "SweetHome3D-2.0.jar" can be found)
5. Click on Ok
Please report here or in bug tracker if it works or not.
Posted by Witold_Krakowski at Jul 20, 2009, 3:07:00 PM
this is a workaround... will it be fixed properly????? does anyone from the dev care about this issue???
Posted by Puybaret at Aug 6, 2009, 6:47:00 PM
Here's a similar and easier one. Click on the following link :
http://www.sweethome3d.eu/SweetHome3D-DirectX.jnlp
I'd loved too but it's not easy for me to find a bug that doesn't happen on my system (and fortunately on almost all systems).
I (until now, the programing team counts one person) care about all bugs, but I can't master bugs that happen in drivers and libraries used by Sweet Home 3D.
One last thing : I recall you that Sweet Home 3D is free and released under GNU GPL license available http://www.gnu.org/copyleft/gpl.txt . The section 15. of this licence clearly states that it this program is provided "as is" without warranty of any kind. So please keep cool!
Posted by cristiano.orlando at Jan 18, 2010, 2:01:22 PM
Fixed it
deleted (from the lib sub-folder, inside Sweet Home 3d folder) j3dcore-ogl.dll
j3dcore-ogl-cg.dll
j3dcore-ogl-chk.dll
That worked like a charm on my computer, now the program runs 3d with no problem
