Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Can I edit furniture from library? |
| Print at Sep 28, 2026, 7:49:27 PM | |
| Posted by Bilfrost at Oct 2, 2020, 9:13:57 PM |
Can I edit furniture from library? Hi All! I am new to SW3D, and enjoying it more than I probably should :). I am now at a standstill because I need a half landing stairwell similar to the one from the imported library by Ola-Kristian Hoff, but with an octogon shape at he half landing (basically cut off the two corners). I tried to export the object and edit it in Meshlab (I am also new to that). However, as soon as I import into Meshlab and export it again, even without making any changes, when I import it back into SH3D, it has lost a lot of its properties, eg. it no longer has all the different materials that can be edited. Is there a recommended way to edit an object? Thanks! |
| Posted by Puybaret at Oct 5, 2020, 5:58:56 PM |
Re: Can I edit furniture from library? You should rather try Blender. It handles very well import / export at OBJ format, keeping materials. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 7:49:27 PM |
