Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how to display a window without circular arc symbol? |
| Print at Oct 11, 2026, 3:40:50 PM | |
| Posted by martinaludger at Oct 5, 2020, 12:50:34 PM |
how to display a window without circular arc symbol? doors and windows cannot be differed in the floor plan a door is shown in the floor plan with a circular arc, which shows the direction of opening. that's OK. Windows are also shown with arcs in the 2D floor plan, just like the doors. But this is not "correct" in a floor plan. correctly, however, they they have to be displayed WITHOUT a circular arc, usually with an additional "center line" in the wall axis. therefore: (how) can I switch off this arc for windows? or can I use another/my own floor plan symbol for windows? |
| Posted by martinaludger at Oct 5, 2020, 1:17:40 PM |
Re: how to display a window without circular arc symbol? see how it has to look: https://id.pinterest.com/pin/756745543621153925/ |
| Posted by AlbertKakiay at Feb 25, 2021, 3:30:00 PM |
Re: how to display a window without circular arc symbol? Recreate Window object and use it, by default it will not contain these parameter in PluginFurnitureCatalog.properties. doorOrWindowSashXAxis#1=75 225 doorOrWindowSashYAxis#1=15 15 doorOrWindowSashWidth#1=75 75 doorOrWindowSashStartAngle#1=0 180 doorOrWindowSashEndAngle#1=90 90 --> Step - Select Window object. - Export to OBJ format (give new name) - Import Furniture (new object) You have new window without Circular arc. |
Current timezone is GMT Oct 11, 2026, 3:40:50 PM |
