Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Online version - change units to metric? |
| Print at Oct 11, 2026, 9:45:35 AM | |
| Posted by Buzko at Oct 7, 2020, 3:01:05 AM |
Online version - change units to metric? Hi all, I'm trying out the online version, but I can't work out how to change the units from imperial to metric. Can you assist? Thanks! |
| Posted by Puybaret at Oct 7, 2020, 5:47:58 PM |
Re: Online version - change units to metric? This is not possible in the current version of the Online version, unless you know how to fool your navigator to let it think you're not in a country which uses imperial system. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wilki at Oct 16, 2020, 10:24:38 AM |
Re: Online version - change units to metric? well, for example, i have the same problem - imperial units instead of metric and i'm in "metric" location... |
| Posted by Julf at Nov 9, 2020, 2:41:35 PM |
Re: Online version - change units to metric? Same here - in metric country, stuck with inches. |
| Posted by MCCG at Jan 8, 2021, 11:51:54 AM |
Re: Online version - change units to metric? Same here, and I can't install the programme locally as I'm getting registry errors :( It would be great to be able to change the units to metric in the online version. |
| Posted by Puybaret at Jan 8, 2021, 5:06:08 PM |
Re: Online version - change units to metric? What registry errors do you get? Maybe you could try to install Java and run the JAR Executable version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by zigmars at Feb 26, 2021, 7:28:31 AM |
Re: Online version - change units to metric? Please repair the on-line version to work with the metric system! |
| Posted by Puybaret at Feb 26, 2021, 9:48:00 AM |
Re: Online version - change units to metric? Be patient, the development of the new Online version is far from being finished. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by CharlesScalliet at May 2, 2021, 8:45:09 AM |
Re: Online version - change units to metric? Is there still no way of working in Metric ? |
| Posted by ferclaverino at Sep 23, 2021, 1:39:11 PM |
Re: Online version - change units to metric? Hi, you can change your language on chrome by settings: https://stackoverflow.com/questions/37221494/...-locale-in-chrome-browser or using an extension: https://chrome.google.com/webstore/detail/loc...haokedippaapkfihdlmmlafcc |
| Posted by Puybaret at Nov 14, 2021, 1:44:44 PM |
Re: Online version - change units to metric? It's now possible to set the unit in the version 6.6.2. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 11, 2026, 9:45:35 AM |
