Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Cannot open File |
| Print at Sep 26, 2026, 10:23:50 PM | |
| Posted by LDG at Oct 16, 2020, 4:16:30 PM |
Cannot open File I hope sombeone could help me, i have some file I can't open. A few are working a few not. Updates are all done include java. Thanks for helping. |
| Posted by Puybaret at Oct 16, 2020, 5:56:20 PM |
Re: Cannot open File Please send me your file. I'll try to fix it if possible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by LDG at Oct 16, 2020, 7:30:35 PM |
Re: Cannot open File Send from Administrator@l****.ch |
| Posted by Puybaret at Oct 16, 2020, 9:06:09 PM |
Re: Cannot open File The 9 files you sent me are full of zeros, i.e. they contain no usable data! Are you sure there are still some valid files on the disk where you found them? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by LDG at Oct 17, 2020, 4:17:01 PM |
Re: Cannot open File Yes because i have the PNG Format of this data. The size of the files are different you mean they are all corrupted? |
| Posted by Puybaret at Oct 17, 2020, 7:51:22 PM |
Re: Cannot open File The files are more than corrupted, they contain absolutely no data. If I were you, I would check if the hard disk where you stored these files is not dying. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by JCPTUK at Jan 10, 2021, 12:01:17 PM |
Re: Cannot open File Hello Puybaret I'm also having problems opening a sh3d file I saved earlier. I was doing a bit of house keeping when I changed a file to "open file with" (different to sw3d file) in file properties, the file type of this particular sh3d file also changed, after searching a bit, I managed to revert the process, ut now it won't open in sh3d. Can you please help. Many thanks Juan PS: As in previous posts, I have checked the Users/Appdata.... folder but there is nothing there |
Current timezone is GMT Sep 26, 2026, 10:23:50 PM |
