Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta |
| Print at Sep 29, 2026, 9:55:53 PM |
| Posted by mmrak at Oct 17, 2020, 7:40:57 AM |
Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Since the latest Update of Big Sur Beta Sweet Home 3D crashes on both my MacBook and on my iMac. I have tested both versions, 6.4.2 (from SourceForge) and 6.4.3 (just purchased from the App Store), both crash at startup, please see attached crashlog. I was able to use Sweet Home 3D without issues since Beta 4 of Big Sur. Any hints or workarounds? Uninstalling and reinstalling did not help. Kind regards Michael |
| Posted by Puybaret at Oct 17, 2020, 8:58:03 AM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Please report this issue to Apple and check bug ticket #976 for workarounds. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mmrak at Oct 18, 2020, 7:51:01 AM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Hi Emmanuel, it did so and sent the bug Reports to Apple. But as I have written above its not the 3D mode that is not working, its the program that crashes at startup. So it might be a different reason. |
| Posted by 61Xray at Oct 25, 2020, 4:31:59 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Hi Emmanuel, The crashlog gives the following error: Exception Type: EXC_BAD_INSTRUCTION (SIGABRT) Exception Codes: 0x0000000000000001, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Application Specific Information: -[NSOpenGLContext setView:] must be called from the main thread. Don't know if this helps. Regards, Michael |
| Posted by mmrak at Oct 28, 2020, 6:40:42 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Hi, is there any progress at this issue? Would be great if this problem could be fixed. |
| Posted by Puybaret at Oct 29, 2020, 9:34:45 AM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta From jkrief report, it looks like the problem is fixed in macOS Beta 11.0.1 20B5012d. If you’re able to install this Beta version, can you confirm? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lfhring at Oct 30, 2020, 4:34:24 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Hi friends: I want to confirm, the program is working well again in 11.0.1 Beta |
| Posted by mmrak at Nov 2, 2020, 7:57:56 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta HI, I can also confirm that the program works again :-) |
| Posted by shabadoga at Nov 28, 2020, 6:21:53 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Hi all, I'm trying to run version 6.4.2 on MacOS 11 Big Sur but i have no success. An alert says me to contact the developer to know if the app is compatible with this version of MacOS. Does anyone have the same problem? |
| Posted by Puybaret at Nov 28, 2020, 7:06:30 PM |
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta Wouldn’t it be because Sweet Home 3D isn’t notarized yet (see bug #951)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 9:55:53 PM |
