Print at Oct 5, 2026, 6:53:36 AM
Posted by DerekvG at Oct 28, 2020, 4:00:49 PM
SH3D on Ubuntu 20.04 LTS
I have resinstalled 2 PC's with Ubuntu 20.04 LTS
the first thing i installed was SH3D because I want to avoid any issues
on My Desktop it works fine.
done the same on my laptop and SH3D doesn't start from the terminal it says command not found while i'm in the folder
HOW can I diagnose what is going on, what info do you need
Posted by DerekvG at Oct 28, 2020, 4:31:06 PM
Re: SH3D on Ubuntu 20.04 LTS
On my laptop installed SH3D as per download page i.e. extracted files to / and maintained the directory structure of the archive
- checked permissions for executable and behaviour = run software
=> doubleclicking Sweethome3D run software starts but the nothing happens
=> for terminal : cd to SH3D directory then SweetHome3D results in command not found
java version :
openjdk version "11.0.9" 2020-10-20
OpenJDK Runtime Environment (build 11.0.9+11-Ubuntu-0ubuntu1.20.04)
OpenJDK 64-Bit Server VM (build 11.0.9+11-Ubuntu-0ubuntu1.20.04, mixed mode, sharing)
Posted by UbuntuBirdy at Oct 28, 2020, 5:46:51 PM
What was your exact command to run it from the terminal? You know, you have to start the command with "./"? So the command you have to type in is "./SweetHome3D" (wihtout "").
Posted by DerekvG at Oct 28, 2020, 6:40:15 PM
indeed that works but
Gtk-Message: 19:20:31.218: Failed to load module "canberra-gtk-module"
The iconspace in the launcher is empty/blank and it says "com-eteks-sweethome3d-SweetHome3D"
starting from Nautilus is still not resolved
created a desktop file as
Posted by UbuntuBirdy at Oct 28, 2020, 8:51:36 PM
Why do you wanna start it from nautilus???
Posted by DerekvG at Oct 29, 2020, 12:37:44 PM
I don't want to start it from terminal because the terminal window stays open. Further more it is not listed in the Application selector
I prefer starting it from Nautilus because I know it works, whereas whan I start if from terminal things go wrong and work gets lost. ( I have been working like that since feb/march of this year whan I reinstalled and had the same problem and instability over and over again.
Moreover I can save the launcher instance to luncher favourites and i can restart it from the launcher bar
The Bundle in the distro is out of date 5.x( if i'm not mistaken) it's not even worth to install
BTW =============
on my last start in Terminal following errors showed up
... ~/SweetHome3D-6.4.2$ ./SweetHome3D
Gtk-Message: 11:28:55.194: Failed to load module "canberra-gtk-module"
Exception in thread "pool-8-thread-1" java.lang.NullPointerException
at com.eteks.sweethome3d.swing.ImportedTextureWizardStepsPanel$19.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Posted by DerekvG at Oct 29, 2020, 12:56:20 PM
this is my .desktop file (on both machines disk config, mount points and directory structure are identical)
[Desktop Entry]
Version=1.0
Name=Sweet Home 3D 6.4.2
GenericName=Interior 2D design application with 3D preview
GenericName[de]=Innenraumplaner
Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview
Exec=/home/derek/SweetHome3D-6.4.2/SweetHome3D
Icon=SweetHome3DIcon
StartupNotify=true
StartupWMClass=com-eteks-sweethome3d-SweetHome3D
Terminal=false
Type=Application
Categories=Graphics;2DGraphics;3DGraphics;
Keywords=interior;design;2D;3D;home;house;furniture;java;
Posted by UbuntuBirdy at Oct 29, 2020, 4:12:21 PM
Not sure if it helps, but try to edit the "Path" and the "Exec" line in your .desktop file like this:
Path=/home/derek/SweetHome3D-6.4.2
Exec="/home/derek/SweetHome3D-6.4.2/SweetHome3D" %U
And then save this .desktop file in
"/home/derek/.local/share/applications"
SweetHome3D will now appear in your applications.
You're right, starting from the terminal is not an acceptable option. But you could even start a software from the terminal with a .desktop with the corect exec line.
Posted by DerekvG at Oct 29, 2020, 9:24:25 PM
Got it to work from Nautilus
I edited the .desktop in /usr/share/applications
and corrected the path to /home/derek (replaced the capitals)
I changed the properties of the file , and in permissions switched off the executable flag and open with text editor.
In Nautilus : Preferences -> Behavior -> Executable Text Files to Ask what to do.
Stopped Nautilus , and rebooted Ubuntu , started Nautilus
In Nautilus : Preferences -> Behavior -> Executable Text Files to Run executable.
I changed the properties of the file , and switched ON the executable flag of SweetHome3D and open with Run software.
and it starts and i could append it to favorites (dock)
Posted by UbuntuBirdy at Oct 29, 2020, 10:10:21 PM
WOW! I tried to help you, and now you showed me how to do it! NICE!
Next time you do not have to reboot Ubuntu, you only quit Nautilus from the terminal with "nautilus -q". And then start Nautilus from where you do it normally.
Posted by DerekvG at Oct 29, 2020, 11:57:52 PM
You helped me, very much, but i think it's good practise to give feedback when it's solved, so when people read the issue they may get an idea how to solve it
In this case yout comments showed i needed to look elsewhere for the problem
Posted by UbuntuBirdy at Oct 30, 2020, 9:41:34 AM
Yes, I agree! It's absolutely important, that you tell us not only that your issue is solved, but how you have solved it!
Thanks for that!
Posted by TechnoTarzan at May 31, 2024, 7:15:14 PM
Hola! I am jumping into this thread because I have a similar problem, but being somewhat of a n00b to Ubuntu, I am having difficulty following along. I am running 24.04 LTS 64-bit on Gnome 46 with Wayland. If you need more details just ask....
My problem is similar when I launch the icon from Nautilus, I right click and Run and it launches the SH3D-7.4 but terminal displays:
~/Downloads/SweetHome3D-7.4$ ./SweetHome3D
Gtk-Message: 11:49:42.052: Failed to load module "appmenu-gtk-module"
Gtk-Message: 11:49:42.057: Failed to load module "canberra-gtk-module"
Any advice is appreciated. Thanks for your work on this app! Going to layout a small house for my daughter.
Posted by TechnoTarzan at Jun 1, 2024, 7:27:51 PM
UPDATE: I was able to remove teh errors above by using these:
sudo apt-get install libcanberra-gtk-module
sudo ln -s /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so /usr/lib/libcanberra-gtk-module.so
sudo apt install appmenu-gtk2-module
sudo apt install appmenu-gtk3-module
When I execute the icon in the SH3D folder, it executes but terminal still loads and the instant I click on FILE to start any task, I get this message:
** (java:81951): WARNING **: 12:25:31.677: Invalid borders specified for theme pixmap:
/usr/share/themes/Breeze/gtk-2.0/../assets/line-h.png,
borders don't fit within the image
** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient
** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient
Hopefully someone has seen this before and help me get up and going?
