Print at Sep 25, 2026, 12:02:58 AM
Posted by Bilfrost at Nov 16, 2020, 5:54:42 PM
Edit length of dimension
Is there a way to edit a ruler ("dimension") to the size I need it to be?
For walls for instance I can edit the wall and enter the length.
For dimensions, all I found was to drag it as long as I need it to be. But often it ends up showing 3 decimals, and since the text is in the middle, in case of a long dimension I cannot even zoom in far enough to fine-tune, because the text is no longer in my screen.
It would be nice if I could right click, modify, and enter the exact size.
Or if this is already possible and I just didn't find how to do it, I would appreciate some help.
I would need this to draw the perimeter of the property around the house.
Thanks!
Posted by dorin at Nov 16, 2020, 8:19:23 PM
Re: Edit length of dimension
You have to read this:
this
and/or
this
Posted by Puybaret at Sep 24, 2023, 3:06:11 PM
The version 7.2 now includes a dialog box which lets you modify start and end points of a dimension as well as other parameters.
