Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: print problem |
| Print at Sep 24, 2026, 7:42:36 AM | View all posts in this thread on one page |
| Posted by insideedgeinteriors at Sep 11, 2009, 11:38:46 AM |
print problem As a new sweethome user, I am finding it easy to create designs but have not yet been able to print them. Would be grateful for info on how to fix this. |
| Posted by Puybaret at Sep 11, 2009, 4:44:12 PM |
Re: print problem I need more information to help you: What's happening when you try to print? On which system do you run Sweet Home 3D? Reading this thread may help you if you're under Windows. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by insideedgeinteriors at Sep 12, 2009, 12:39:04 PM |
Re: print problem I am using windows XP, but have now found if I save as PDF it will print. Any other advice would be great |
| Posted by Puybaret at Sep 12, 2009, 2:48:15 PM |
Re: print problem Please try the solutions described in the FAQ. Using DirectX solution seems to resolve the problems of most users. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 7:42:36 AM |
