Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: White lines on ground (from walls of lower floor) |
| Print at Oct 4, 2026, 1:58:35 PM | |
| Posted by Chrack at Dec 4, 2020, 11:04:58 PM |
White lines on ground (from walls of lower floor) Hi - my level 0 displays the wall outlines from a lower floor on the ground as white lines? Can I switch this off? Thanks! |
| Posted by Puybaret at Dec 5, 2020, 8:26:09 AM |
Re: White lines on ground (from walls of lower floor) No but these ghost lines won’t appear if you print, copy-paste or export the plan (as well as the selection rectangle around furniture). Do they bother you so much? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 1:58:35 PM |
