Print at Sep 28, 2026, 9:59:15 PM
Posts: 12   Pages: 2   [ 1 2 | Next Page ]
Posted by Ciap at Dec 12, 2020, 7:52:12 PM
sad   SH3D on Raspberry pi 4 - problems with GUI
I've installed SH3D on Raspberry PI 4 (no problems there) but whenever I open the program it's full of black boxes that change when I move a coursor, add a new component or open a menu. Examples of above problems can be seen on these pictures:
Is this a problem with Rapis' support of 3D graphics? Or do I have to manually enable some 3D related functionality? I'm to new to 3D graphics programs on Raspi so I would appreciate any help :).
Thanks in advance!
Posted by Puybaret at Dec 14, 2020, 11:41:49 PM
Re: SH3D on Raspberry pi 4 - problems with GUI
I didn't know that it was possible to run Sweet Home 3D under Raspberry PI! How did you run it since it's an ARM processor?
Posted by UbuntuBirdy at Dec 15, 2020, 3:19:40 PM
I'm in the exact same situation. I've installed SH3D from the Software Center in Ubuntu 20.10 and it's running out of the box, but with the limitations that Ciap mentioned.
Posted by sharkfamily at Dec 17, 2020, 4:49:14 AM
I too, use ARM and have aforementioned effect when working in SH3D. I found using a larger monitor connected to my (NanoPC-T4) SBC but its persistent. I used aptitude installer in my distro, as soon as i think its poke-able with a Bluetooth keyboard I will launch it on the PinePhone.
Posted by UbuntuBirdy at Dec 17, 2020, 6:45:47 PM
Changes with LookandFeel and increase the Xmx to 2Gb do not solve the problem.
Posted by Ciap at Dec 17, 2020, 7:07:52 PM
1. Puybaret, I did it through the terminal by typing "sudo apt install sweethome3d". As far as I know you can also do it in the "Add/Remove software" app. It seems that it's a proper distribution for an ARM processor.
2. UbuntuBirdy, thanks for the help!
3. I think that the problem is Java distribution. I was able to test it on Raspi 3 and it runs perfectly. The only difference I've noticed was Java version. Raspi 3 uses Java 8 while Raspi 4 uses Java 11. As of now I was not able to force Raspi 4 to use Java 8 for SH3D. Even when I had only Java 8 on my Raspi, downloading SH3D forced me to also download and install Java 11. Morover, when I set Java 8 as default, SH3D still used Java 11. Uninstalling Java 11 also uninstalls SH3D.
If that's helpfull, I'd be grateful for any further advice.
Posted by dorin at Dec 19, 2020, 8:32:07 AM
My best answer is in this post .
Use the official installer version!
Forget repository!
Posted by UbuntuBirdy at Dec 19, 2020, 10:31:32 AM
@dorin - This is what I tried first because I normally always use this version, but it did absolutely not work! It is not made for ARM...
Posted by dorin at Dec 19, 2020, 4:03:38 PM
@ UbuntuBirdy
Sorry, but when I see apt (or similar) I remember I spend 5 years to understand that's the problem.
Back to work.
Let's see how to analyze this problem.
1. I talk with You because You have more experience.
2. Short preamble:
2.1 The processor usually (always) are commended by OS
2.2 Applications (including Java) work with OS
2.3 CPU<=>OS<=>App
2.4 So if OS can run a Java application could run every this kind of.
2.5 If don't, the OS complain and report what don't like it.
3. Install SH3D as normal user (not root). YES, I knew You've done already
3.1 Install (same mode) AOI which is also a java.
4. First try to run AOI and see if it work (probably yes)
4.1 Try SH3D to run normally (double click or similar)
4.2 Try SH3D with a clean .eteks/shweethome3d folder
5. If 4.1 and 4.2 fail try to run from terminal and see the massages
5.1 Try the same with AOI if don't work from normal start
6. Java want to be a cross platform which mean cross OS not cross processor.
6.1 When I try to do something in java > 9 +j3d-6 I was informed that j3d are not supported anymore.
6.2 What Java 9,10,11 offer in place is far to be acceptable
7. It's interesting to know if an OS could force an application to use what he what not what application need.
Posted by UbuntuBirdy at Dec 19, 2020, 10:02:21 PM
@ UbuntuBirdy
I made exactly the same experience!
Thanks for your effort, but the Raspi is only a game for me. I'm running SH3D on my Ryzen machine. Even a SH3D without issues on a Raspberry Pi is not usable because it (the Raspi) is too slow... A very small project may work, but my projects are way to big to deal with on a Raspi.
But if I'm bored during the coming weeks, it could be that this game attracts my mind... But not yet...
