Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Creating a simple 1" x 4" wall trim |
| Print at Oct 12, 2026, 12:54:20 AM | |
| Posted by Ruskinite_2 at Jan 2, 2021, 7:35:58 PM |
Creating a simple 1" x 4" wall trim Hi all - Just bought SH3D and have been using it for a couple of days now, but I just can not find a way to add a simple [wood] trim (1" x 4" wall) to rooms that can be also used along the floors as baseboard (1" x 6"). I'd need to be able to adjust the trim's distance from the ceiling (i.e. dropped about a foot from the top) as well as adjusting the depth (i.e., how far it protrudes out from the wall). I would think that'd be a simple polygonal shape with parameter tweaks but I can't find that anywhere in the models or features. Here is the wood trim look I'm talking about... Thanks! |
| Posted by Shralen at Jan 2, 2021, 8:41:01 PM |
Re: Creating a simple 1" x 4" wall trim In your SH3D you should have a piece of furniture called Box, select that and drag it in your project. Then you can change the size and height to fit your room. ![]() In case the image broke: https://sta.sh/01138nje06xy For baseboard, click on the wall you want to add a baseboard, then go to 'modify baseboard' then modify as you'd like. ![]() In case the image broke: https://sta.sh/025aj598pp2k ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Ruskinite_2 at Jan 3, 2021, 10:31:48 AM |
Re: Creating a simple 1" x 4" wall trim Thank you!! Both suggestions worked! |
Current timezone is GMT Oct 12, 2026, 12:54:20 AM |
