Print at Sep 29, 2026, 2:19:02 PM
Posted by paolocesari at Jan 6, 2021, 7:05:57 AM
Floor shadow on the ceiling
after creating a model with some levels, on 3D view I've found the floor shadow on the ceiling.
Here the some examples:
And my levels:
How can I solve the problem?
Thanks to all!
[Note from moderator: fixed links to images, be sure to use "Direct Link" option]
Posted by Puybaret at Jan 6, 2021, 4:38:21 PM
Re: Floor shadow on the ceiling
This must be the ceiling of some rooms. The height of a level is used to compute the elevation of ceilings and you should enter the height of the level, not the altitude of the ceilings.
So I guess the last column of your level modification dialog box should rather display 320.
Posted by paolocesari at Jan 7, 2021, 5:01:20 AM
I'm really stupid, as you say the height of the rooms should be set at 320 cm.
Problem solved, thank you very much!
